HWACHEON HI-TECH350 Lathe post
MSL
Hi,
 I'm modifying a post for Hwacheon HI-Tech350 Lathe. I need to output H value for axis substitution. The H is C's  incremental address.Can someone help me on this please? below is the G-code sample. Thank you.
N3(TOOL - 3 OFFSET - 3)
( 1/8 FLAT ENDMILL)
(HWACHEON HI-TECH350 YSMC)
(MACHINE GROUP-1)
G0G18G40G80G99
G54
G0G28U0
G28V0
G53Z-8.5
N3 T0303
G18 G98
M28
G28 C0
M8
M39(MAIN CLAMP OFF)
G0 C0.
M38(MAIN CLAMP ON)
G0 X1.2075 Z-.2895 S4200 M103
G18 H0. W0.
G07.1 C.304
G1 X1.1075 C1.235 F500.
X.6887 F3.
Z-2.6163 H-1064.367 F15.
Z-2.4849
Z-.2895 H1004.26
C1.235
Z-.2775 C12.662
Z-2.6343 H-1078.055
Z-2.4769
Z-.2775 H1006.074
C12.662
Z-.2655 C24.088
Z-2.6522 H-1091.743
Z-2.4689
Z-.2656 H1007.845
Z-.2655 C300.232
C300.289
C24.088
Z-.2625 C26.628
Z-.2626 C26.901
Z-.2628 C26.795
Z-2.656 H-1094.697
Sorry, but sample code is a little odd why are you switching between Absolute and Incremental output? What post are using as a base post? I have built 4 different variants of posts for these machines years ago.
Look in the pcout and pfcout for result = nwards(strc, cabs) one of these section will need to be modified to output the H for the Sub Spindle. If you are not using a lower turret then you should be okay, but if you are using a lwoer turret on the right spindle be aware of the bug still present where a trick has to be used to get output in the Axis Columns to get correct output. Jimmy Wakeford helped me years ago and you can see the trick with the _ron added to the 4th section of the code.
#Columns-    ABCDEFGH.IJKLMNOPQ
scase_br_c1  : "11000222.111111111"  #Bottom turret/Right spindle, Turning cut
scase_br_c2  : "11000012.111111111"  #Bottom turret/Right spindle, Right Face cut
scase_br_c_2_ron : "11110012.011111111"  #Bottom turret/Right spindle, Left Face cut
scase_br_c_2 : "11110012.111111111"  #Bottom turret/Right spindle, Left Face cut
scase_br_c3  : "11010102.111111111"  #Bottom turret/Right spindle, Cross cut (cuttype = 3)
scase_br_c3r : "11010102.111111111"  #Bottom turret/Right spindle, Reverse Cross cut (cuttype = -3)
scase_br_c4c : "11000222.111111111"  #Bottom turret/Right spindle, Y axis subs. Cycle
scase_br_c4  : "11000222.111111111"  #Bottom turret/Right spindle, Y axis subs.
scase_br_c5  : "11000222.111111111"  #Bottom turret/Right spindle, Multisurf Rotary
It had to be added here:
pltype2         #Bottom turret/Right spindle
      ##"RON_NOTE1 -------------- ",~cuttype,e$
      if cuttype = one,
        #Lathe
        max_speed = max_speedl2
        min_speed = min_speedl2
        sw_string = scase_br_c1
      else,
        #Mill
        max_speed = max_speedm2
        min_speed = min_speedm2
        sw_string = scase_br_c2 #case two is the default
        if cuttype =  -2,sw_string = scase_br_c_2_ron ####new _ron setting
        #if cuttype =  -2,sw_string = scase_br_c_2    ####old busted setting
        if cuttype = three, sw_string = scase_br_c3
        if cuttype = -3, sw_string = scase_br_c3r
        if cuttype = four & abs(c1_millcc) = one, sw_string = scase_br_c4c
        if cuttype = four & c1_millcc = zero, sw_string = scase_br_c4
        if cuttype = five, sw_string = scase_br_c5
and here there was a change:
psw_str_mult    #Apply sw_string to variables and strings
      ##"RON_NOTE2 ------------------------  ",~sw_string,e$z
      #c axis type
      #c_axistype = plcval (sw_string, 8)    #c_axistype comes from machine def
      if rot_index = 1, c_axistype = 3
      else,
        if rot_type = 0 | rot_type = 2, c_axistype = 1
        if rot_type = 1, c_axistype = 2
      #reverse spindle
      spd_rev = plcval (sw_string, 7)
      #plane 0
      rslt_plc = plcval (sw_string, 6)
      if rslt_plc = zero,
        sg02 = sxg02
        sg03 = sxg03
        sg41 = sxg41
        sg42 = sxg42
      else,
        sg02 = sxg03
        sg03 = sxg02
        sg41 = sxg42
        sg42 = sxg41
      #plane 1
      rslt_plc = plcval (sw_string, five)
      if rslt_plc = zero,
        sg02_1 = sxg02
        sg03_1 = sxg03
        sg41_1 = sxg41
        sg42_1 = sxg42
      else,
        sg02_1 = sxg03
        sg03_1 = sxg02
        sg41_1 = sxg42
        sg42_1 = sxg41
      #plane 2
      rslt_plc = plcval (sw_string, four)
      if rslt_plc = zero,
        sg02_2 = sxg02
        sg03_2 = sxg03
        sg41_2 = sxg41
        sg42_2 = sxg42
      else,
        sg02_2 = sxg03
        sg03_2 = sxg02
        sg41_2 = sxg42
        sg42_2 = sxg41
      #plane 0
      rslt_plc = plcval (sw_string, three)
      rslt_upd = updstr (swstr)
      sg17 = swstr
      #plane 1
      rslt_plc = plcval (sw_string, two)
      sg19 = swstr
      #plane 2
      rslt_plc = plcval (sw_string, one)
      sg18 = swstr
      #plane 0, x axis
      rslt_plc = plcval (sw_string, m_one)
      pl_ax_m0x = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -2)
      pl_ax_m0y = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -3)
      pl_ax_m0z = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -4)
      pl_ax_m1x = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -5)
      pl_ax_m1y = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -6)
      pl_ax_m1z = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -7)
      pl_ax_m2x = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -8)
      pl_ax_m2y = -((rslt_plc * two) - one)
      rslt_plc = plcval (sw_string,  -9)
      pl_ax_m2z = -((rslt_plc * two) - one)
Ron,
Thank you for your respond. The machine does not have bottom turret. It has top turret with main and sub spindle. I'm trying to use axis substitution on main spindle. The base post is Generic Fanuc 4X MT_Lathe. It was odd for me too switching between Absolute and Incremental. I got the G-code sample from Selway.
Thank you.
