2D DYNAMIC ISLAND FACING
manel
12 minutes ago, JParis said:
Can you share your file
look at this document , we can do island facing with 2D high speed, i dont know how to define the geometrie,
7 hours ago, JParis said:
2 seperate toolpaths - ....unlike island pocketing there is no option for island pocketing
or......
If you have a solid, use a Dynamic Opti-Rough
sorry i cant , thanx for your help , all i need to know is how to make island facing in 2D dynamic mill
in the pdf i shared , this can be done like pocket island facing
but i dont know how to select geometry so it can do the island facing
please help
5 minutes ago, JParis said:
Your pocket geometry should be at the bottom of the pocket.....define the island geometry at the depth that is the top of the island
where i can define the depth of the top of island, i dont find the function ,
or......
please help
  • 3 weeks later...
If the island is at the same height with the top of the part  you only need 2d geometry. I usually set Z zero at the top of the part.
In the Dynamic Mill toolpath, select as Machining region the pocket chain and as Avoidance region the island chain. (2018 - I do not know what version of Mastercam are you using)
In the Linking give the depth of the  pocket -1 (If the  pocket is 1" deep)
If the island top is below the top of the part you need to create the geometry used in the toolpath at the proper z depth.
In my next example, z zero is at the top of the part; the pocket depth is  at -1" and the top of the island is at  - .25  (both measured from Z zero).
Create the 2D geometry at z zero.
Use Translate command to move the chains at the proper Z depth:
    Select the pocket geometry (Hold down the shift key and select one of the pocket entities)
    In the panel, enable Move and enter in the z field -1.
     Repeat the step for the island chain and enter Z-.25.
If you want to face the island, in the Depth Cuts:
   enable Use Island depths
   enable Island facing and give an Overlap 25% or more.
In the Linking give the Depth incremental and 0.0.
