Using mi3
mayday
is this possible, I havnt had to much luck yet. mostly my ignorance headscratch.gif
in our standard controls this is the output for G00,G01.
# Motion G code selection
sg00 G00 #Rapid
sg01 G01 #Linear feed
sg02 G02 #Circular interpolation CW
sg03 G03 #Circular interpolation CCW
sg04 G04 #Dwell
sgcode #Target for string
fstrsel sg00 gcode sgcode
now in the high speed contorls I want to use mi3 as a toggle like this
Use High Speed Codes [0=No, 1=Yes] (mi3)? 0
if #1 is selected then this change should happen
sg00 G00G64
sg01 G01G64.1
I cant get the argument to work, I can hard code it but this is the only diferance between the 2 posts right now, and I would like to use just 1 post
any help?
MayDay,
Like this?
This is not hard-coded in the 'sgcode' string selection.
O0001
(PROGRAM NAME - SURF-ROUGH-CONTOUR-ENTRY-EXIT-ARC )
(DATE, Day-Month-Year - 10-02-04 TIME, Hr:Min - 13:59 )
N100 G20
N102 G0 G17 G40 G49 G80 G90
( 1/8 FLAT ENDMILL TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - .125 )
N104 T2 M6
N106 G0 G64 G90 G54 X9.75825 Y5.15887 S4278 M3
N108 G43 H2 Z3.06353
N110 G1 G64.1 Z2.71353 F6.16
N112 X6.44703
N114 G0 G64 Z2.96353
N116 Z3.06353
N118 X6.41202 Y5.25733
N120 G1 G64.1 Z2.71353
N122 X9.79326
N124 G0 G64 Z2.96353
N126 Z3.06353
N128 X9.79626 Y5.35579
N130 G1 G64.1 Z2.71353
N132 X6.40903
N134 G0 G64 Z2.96353
N136 Z3.06353
N138 Y5.45425
N140 G1 G64.1 Z2.71353
N142 X9.79626
N144 G0 G64 Z2.96353
N146 Z3.06353
N148 Y5.55272
N150 G1 G64.1 Z2.71353
N152 X8.6619
N154 X8.65585 Z2.71737
N156 X8.65525 Z2.71876
Here's how I do it,
pcctrlon
if mi8 = 1, pbld, n, "G8P1", "(LOOK-AHEAD ON)", e
if mi8 = 2, pbld, n, "G5.1Q1", "(AICC ON)", e
if mi8 = 3, pbld, n, "G5P10000", "(HPCC ON)", e
prv_mi8 = mi8
!mi8
pcctrloff
if prv_mi8 =1, pbld, n, "G8P0", "(LOOK-AHEAD OFF)", e
if prv_mi8 =2, pbld, n, "G5.1Q0", "(AICC OFF)", e
if prv_mi8 =3, pbld, n, "G5P0", "(HPCC OFF)", e
!mi8
Then I have the calls in ptlchg_com (I think)program where I need the output to be. Also I initialized the post block in the general settings.
James may be slow at math, but he can type pretty fast.
MayDay,
How you approach this depends on when/where you need the codes to output. If you can just turn ON the mode at the toolchange and off at the end of the tool - you can go wih James' method.
BUT, If you need to turn the mode ON/OFF at each change in G0->G1 or G1->GO, that approach is not going to work for you.
James can be slow at math
Im prolly no faster,sure of that
and am really slow at this post stuff but what the hay, how else am I gonna learn.
I'll try and beg a little more Roger,THANKS
thats twice in one day you showed me a sample post to use.
P.S.
the G84.2 works good
I should have stipulated that the codes only need to be turned on at a tool change and off at the end of a cycle. If it needs to be on and off according to what G code is active, then Roger's method is the way to go.
