Another Okuma Question; High Speed Look Ahead
danielm
Well it turns out that   VOPRB[2]=VOPRB[2] EOR 128   is just a toggle switch that change the state of the HSLA buffer from off to on  or on to off....depending on its initial state.
VOPRB[2]=VOPRB[2] OR 128   Turns the HSLA buffer off no matter what
There has got to be a similar string that turns the HSLA buffer on no matter what.  I've been through the manuals and I cant find it.
Anyone run into this?
Thanks in advance for any help.
VOPRB[2] is an 8 bit (0-7) parameter. Bit seven determines whether or not buffering is on. For buffering to on, bit seven needs to be a 0. To always set it to be on you will need to do some logic checking.
IF [VOPRB[2] LT 128] NSKP1
VOPRB[2]=VOPRB[2]-128
NSKP1
Also, for reference, you can check the VDIN variable to act as a one line look ahead limit in a program. VDIN[****] (where **** = 1000-1004) are system clocks for days, hours, minutes, seconds, milsec. If you write any one of those values to a variable the NC will not process that line of code until it reaches it in actual execution. This will act as a look ahead buffer.
Example;
TIME=VDIN[1001]
