okuma lathe cutter comp
We have a new post for programming Okuma lathes. A problem I am having is for finish cuts it applies cutter comp during a G00 move. That causes the machine to alarm out. I must then edit the NC file to apply the cutter comp at the first G01 move. Is there a way to get the post to do this? I see in canned cycles you have a bit of cutter comp control, but not so much in contour ops.
Yeah, sure. What Okuma was demanding was that the G41/42 line needed both an X and a Z value. It did not necessarily need to be a G1 output. For some reason the X and Z outputs were on separate lines. I moved the xout to the same line as the zout in the tool change setup and everything worked well.
