Stock Models
Manofwar
I'm currently working on a part that is using stock models. I'm seeing an issue when I try to put two paths that are 180 degrees from each other the stock model shows a giant hole through it. It's like it is processing only the linear moves of the machine, and having to violet the part to get back to the correct plane when it rotates. Is there a way around this except creating two separate stock models?
It's actually the stock model itself. Here's a picture of what I'm seeing. (I can't share the file.) I could do Multiaxis Linking, but that would be creating more files which is what I'm trying to avoid. When the path finishes and goes to the next path (180 degrees from the first path) it shows the tool traveling right through the part, instead of rotating or even teleporting the tool to the other side.
