OKUMA OPS700L LATHE 2 AXIS HELP
HI  need help how to add this line   NAT04
DEF WORK
PS LC,[0,0],[0,0]
END
DRAW
N002G00 X20 Z31.5
N003 G50 S1800
(NAT00
CALL OLOAD)
N004 M01
N005G00 X20 Z31.5
NAT04    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADD THIS  LINE
N006 G97 S1000 M42 M03 M08
N007 (****************** FACE **************)
N008 X1.168 Z0 T040404
N009 G97 S1000
N010 G01 X-.132 F.005
N011 Z.05
N012 G00 X19.968 Z19.984
NAT is typically used as a sequence number. I use NAT for sequence numbers and NLAP numbering for LAP cycles.
In reply to Cathedral, NAT has nothing to do with LAP cycles (actually neither does NLAP, you can just use normal N numbers).
You're right. It just depends on how you program. For example, I program our canned cycles like so:
N1 (OD 452 MAIN)
G97 S982 M03
G95
G00 Z0. T010101
M08 M101 M105
X1.625
G96 S450
G95
G85 NAT02 D.05 F.015 U.01 W.01
NAT02 G81
G80
We only use sequence numbers (N) at the start of a toolpath to make restarting easier. But I can see how--if you used sequence numbers all the time--you would want a different callout for the start of the toolpath.
THE operator got use to      NAT
I TRY UNFORNTUNATLY,  IT COME OUT  NAT0001
fmt  "NAT" 7  toolno1      #Tool number
  toolno = t$ * 100 + tloffno$
          toolno1 = t$   #t$   ####  MOD  ADD LINE ****
          ptoolcomment
       # pbld, n$,"G00","X20.","Z31.5"  e$
           pbld, n$,toolno1  e$
(PROGRAM NAME = 10-32 FLEX ARM TAP)
(  OKUMA 2 AXIS *JR*- DATE -  APR.   21.  2015 )
G00 X20. Z31.5
G50  S1800
( NAT00
CALL OLOAD )
M01
( *** TOOLIST****  )
(TOOL = 1 OFFSET - 1. OD FINISH RIGHT - 35 DEG.)
(TOOL = 3 OFFSET - 3. DRILL .159 DIA.)
(TOOL = 2 OFFSET - 2. .125 THK GROOVE CUTOFF)
(TOOL = 1 OFFSET - 1)
(OD FINISH RIGHT - 35 DEG.  INSERT - NONE)
NAT0001  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  it  should be  NAT01   HELP PLEASE
N1 G0 T0101 M42
M8
G97 S1500 M03
( ******************* FACE*************** )
G0 X1.2 Z.02
G50 S1500
G96 S1000
G99 G1 Z0. F.005
X-.0313
Z.1
G0 Z.2
