5AX Sawrf with Cutter Comp - Heidenhain 640
Greg Williams
Hi All,
I have been running some test on a new DMU50 with a TNC640 with 5AX swarf and cutter compensation, so far, I have not managed to get a result. I suspect either my format is incorrect, or I have not entered the tool radius values into the tool table in the correct spot. Has anybody managed to get this to work?
I have tried these different formats
______________________________________________________________________
34 PLANE SPATIAL SPA+0 SPB+7.057 SPC+175.236 TURN F MAX SEQ+ TABLE ROT
35 L X+12.599 Y-14.939 F MAX
36 L B+7.057 C+175.236 F MAX
37 L Z+72.335 F MAX
38 PLANE RESET STAY
39 M128
40 L X-20.076 Y+16.664 Z+70.239 B+7.057 C+175.236 F MAX
41 M08
42 L X-7.955 Y+15.654 Z-28.011 B+7.057 C+175.236 F MAX
43 L X-7.833 Y+15.643 Z-29.004 B+7.057 C+175.236 RL F600
44 L X-8.611 Y+15.691 Z-29.1 B+7.057 C+175.236 F1114
Also
16 TOOL CALL 63 Z S3183
17 CYCL DEF 32.0 TOLERANCE
18 CYCL DEF 32.1 T+.01
19 CYCL DEF 32.2  HSC-MODE:0 TA+.1
20 L B-7.057 C+355.2355 FMAX
21 PLANE SPATIAL SPA+0 SPB-7.057 SPC-4.7645 STAY SEQ- TABLE ROT
22 L X-20.0759 Y+16.6638 FMAX M3
23 PLANE RESET STAY
24 M128
25 L X-20.0759 Y+16.6638 Z+70.2388 NX-.0611828 NY-.9981229 NZ+.0027151 RL FMAX
26 M8
27 L X-7.9551 Y+15.6535 Z-28.0112 NX-.0611828 NY-.9981229 NZ+.0027151 FMAX
28 L X-7.8326 Y+15.6433 Z-29.0036 NX-.0611828 NY-.9981229 NZ+.0027151 F600
29 L X-8.6105 Y+15.6908 Z-29.1001 NX-.0352313 NY-.9993616 NZ+.0059294 F1114
30 L X-9.3899 Y+15.6971 Z-29.1963 NX+.0167265 NY-.9997839 NZ+.0123437
And
FUNCTION TCPM F TCP AXIS POS PATHCTRL VECTOR REFPNT TIP-TIP
CYCL DEF 32.1 T+.0015
CYCL DEF 32.2 HSC-MODE:1 TA+.5
M8
L X-7.9551 Y+15.6535 Z-28.0112 C-184.764 B+7.057 FMAX
L X-7.8326 Y+15.6433 Z-29.0036 FQ1601
L X-8.6105 Y+15.6908 Z-29.1001 FQ1600
L X-10.1686 Y+15.6623 Z-29.2921
L X-10.9444 Y+15.5865 Z-29.3871
L X-23.1247 Y+5.821 Z-30.7944
L X-23.3724 Y+5.0762 Z-30.8177
L X-23.5811 Y+4.3193 Z-30.836
L X-23.7502 Y+3.5525 Z-30.8493
L X-23.8792 Y+2.778 Z-30.8577
L X-23.9679 Y+1.9977 Z-30.861
L X-23.9759 Y+1.9061 C-184.545 B+7.0572 RL
L X-23.9895 Y+1.7158 C-184.091 B+7.057
They all seem to load and run but not actually offset the tool at all. Has anybody managed to get this to work?
You  would need vector output  , not XYZ AB output to be able to move the tool in the right direction away or into the material....
Gracjan
My bad ... you do have vector output on some of the lines. I'll have to try this on my machine.....
Gracjan
