Contour with .00005 taper
Leon82
I have a square with radii in the 4 corners. Tool path tolerance it .00001.
On all 4 sides the posted code is moving.00005 along each length. The geometry is straight I even drew new geometry if I annalize with six place decimals it's a straight line..
The post is set for 6 place decimal. Will adjusting the system tolerance help this?
This is probably just an issue with rounding of the numbers in Windows.
Do a Google Search for 'round_opt$' on this site.
Can you share a file?
Which version of Mastercam? You can use native vbscript tools to output the precise value in a message box of the selected lines endpoints.
It might not be in the right view, then you would combine views or something.
There is intellisense in code expert for the language
Dim success
success = StartDBSearch(MC_SELECTED,MC_LINETYPE)
If success Then
    Do
	       Dim Line
           Set Line = New mcLn
           If GetLineData(GetEntityEptr, Line) = True Then
			  ShowString("Line end point1->" + "x" + Cstr(Line.X1)  + "y" + Cstr(Line.Y1) + "z"  + Cstr(Line.Z1) + " Line end point2->"+ "x" + Cstr(Line.X2)  + "y" + Cstr(Line.Y2) + "z"  + Cstr(Line.Z2))
           End If
    Loop While NextDBSearch
End If
2020.
1 hour ago, Colin Gilchrist said:
So, try the following (one at a time), to test the 'round_opt$' variable:
round_opt$ : 0
round_opt$ : 1
round_opt$ : 11
round_opt$ : 21
Thanks, I will give it a shot tomorrow
I will try. I need to strip it of customer data
2 hours ago, Leon82 said:
That variable is not in the post
No, it isn't.
This is something that you have to add to your Post, if you want to test it out. It is kind of a 'secret option'.
That MP variable instructs MP.DLL to utilize a different Windows Function for rounding a double value. (All numbers are stored as the Double Type in MP.)
Add the variable initialization, starting with the 'r' in the very 1st column of your editor.
Only add one line, and then change the 'initialization value', each time you run the test. (Be sure to sve the Post between the tests!)
round_opt$ : 11
There are 4 different values to try: 0, 1, 11, 21.
