khass0410
Lathe 3D Tool
Hi all, thanks for the help in advance. I downloaded our Lathe cut off tool holder and insert from the Iscar website and have been trying to make a Lathe 3D tool work. I think I am fairly close. My problem is when I backplot the insert is not making contact with the part. If I use a Lathe standard tool with the same toolpath everything looks correct. The attached file is the Lathe 3D tool making no contact and the standard tool making contact with the same toolpath. Any help or advise would be appreciated.
krh - 3D Tools.mcam
krh - 3D Tools.mcam
Good topic covering 3D tools was shared here.  Sight unseen most times a programmer forgets to define the width of the insert.
https://forum.mastercam.com/FindPost41758.aspx
12 minutes ago, khass0410 said:
Just downloaded them. Will watch soon. Thank you.
I back plotted the file and everything looks good to me. Now if you are referring to the Center distance issue then that is where you need to use the offset function when defining your tool cutting plane and it's offset.
That is found here:
I changed it to negative of the picked point vale and got this:
Now insert is perfectly on center:
That is found here:
So I just changed that. Didn't realize that setting was for that. I'm still seeing a small gap between the insert and part. Maybe I'm being to picky?
Yes you are being way to picky.
  • Haha 1
