strstr function not recognizing the character ±
I'm trying to catch special characters before they get posted, our MAS system won't allow them.
I was successful with the characters "(", ")", and "°"
but when I put in the "±" it won't find it in the string.
Is there a way to make it recognize this character?
Below is the code I used to check for parenthesis in the tool name. The code below that worked when I put "°" in there, but not "±"
Also, is there a way to run strstr on a list of characters without having to copy the code each time?
Or... would it be easier to get a list of the allowable characters and check against those.
It appears that ± isn't in the post. I'm sure I would have tried it in my inspection program.
"DPRNT[***DISTANCE*", *drl_prm7$, [if drl_prm6$, "*TOL*+/-*", <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                 *drl_prm6$], "***]", e$
********************************PRINT***********************************
                spaces$ = 0
                 "POPEN", e$
                if s_popen_flg = 0,
                  s_popen, e$
                  s_popen_flg = 1
                "DPRNT[]", e$
                "DPRNT[-----------------------------------------------------------]", e$
                "DPRNT[***", s_sav_comment , "***]", e$
                "DPRNT[***RESULTS***DISTANCE*#138[24]***]", e$
                "DPRNT[]", e$
#                "PCLOS", e$
                spaces$ = sav_spc
Instead of defining the ± in the "initialization", you may have to use the 'no2asc' function to make sure the correct bits are held in that variable.
Rather than repeating the code for each ASCII character, I'd try constructing a While Loop, and use a common "search string variable".
str_test : "" #empty string
str_warn : "" empty string
pmyblock
      str_test = no2asc(171) #Convert ASCII Code decimal value to Plus/Minus string representation
      pstr_test
       str_test = no2asc(40) #Convert ASCII Code decimal value to Left Paren string representation
      pstr_test
      str_test = no2asc(41) #Convert ASCII Code decimal value to Right Paren string representation
      pstr_test
pstr_test
      result = strstr(str_test, strtool$) #Test string for character assigned with no2asc
      if result <> 0,
        str_warn = "BAD CHARACTER " + str_test + " FOUND IN strtool$ NAME." + no2ascii(13) + "FIX COMMENT AND REPOST!"
        result = mprint(str_warn)
Thanks Colin, I got it to work with the following code. Not pretty, but it does the trick.
str_testTool : "" #Empty String
str_warnTool : "" #Empty String
str_testComment : "" #Empty String
str_warnComment : "" #Empty String
str_CheckComment : "" #Empty String
ptoolCharacterCheck
      str_testTool = no2asc(33)            #no2asc(33) #Convert ASCII Code decimal value to ! string representation
      pstr_testTool
      str_testTool = no2asc(40)            #no2asc(40) #Convert ASCII Code decimal value to ( string representation
      pstr_testTool
      str_testTool = no2asc(41)            #no2asc(41) #Convert ASCII Code decimal value to ) string representation
      pstr_testTool
      str_testTool = no2asc(176)            #no2asc(176) #Convert ASCII Code decimal value to ° string representation
      pstr_testTool
      str_testTool = no2asc(177)            #no2asc(177) #Convert ASCII Code decimal value to ± string representation
      pstr_testTool
pOperationCommentCheck
      str_testComment = no2asc(33)            #no2asc(33) #Convert ASCII Code decimal value to ! string representation
      pstr_testComment
      str_testComment = no2asc(40)            #no2asc(40) #Convert ASCII Code decimal value to ( string representation
      pstr_testComment
      str_testComment = no2asc(41)            #no2asc(41) #Convert ASCII Code decimal value to ) string representation
      pstr_testComment
      str_testComment = no2asc(176)            #no2asc(176) #Convert ASCII Code decimal value to ° string representation
      pstr_testComment
      str_testComment = no2asc(177)            #no2asc(177) #Convert ASCII Code decimal value to ± string representation
      pstr_testComment
pstr_testTool
      result = strstr(str_testTool, strtool$) #Test string for character assigned with no2asc
      if result <> 0,
        str_warnTool = "BAD CHARACTER " + str_testTool +  " FOUND IN" + " T#" + no2str(t$) + ", TOOL COMMENT IS "  + strtool$ + " NAME." + " PLEASE FIX COMMENT AND REPOST!"
        result = mprint(str_warnTool)
pstr_testComment
      str_CheckComment = scomm$
      result = strstr(str_testComment, str_CheckComment) #Test string for character assigned with no2asc
      if result <> 0,
        str_warnComment = "BAD CHARACTER " + str_testComment + sbubbleinfo + " FOUND IN OPERATION " + drs_str(2,opnumber) + ", COMMENT IS "  + str_CheckComment + " PLEASE FIX COMMENT AND REPOST!"
        result = mprint(str_warnComment)
