Not a mastercam question, but....
biss03
A fellow employee asked me about this math equation brought to her by her son last night. I think I derived the correct answer (boy did this bring back memories), but thought I would present it to all on this forum. You guys are sooo good at answering all other questions I figured why not!!
Here is the problem:
8(20+y+x)
good luck and thanks,
josh
  • Replies 66
  • Created
  • Last Reply
Top Posters In This Topic
I may be wrong because it's only been 20 years since algebra but here goes:
160+8x+8y
unless they had an = sign to figure a variable
So is it right or should I stick to programming?
[This message has been edited by Bill (edited 06-06-2001).]
Exactly, Bill. Hard to tell what we're solving for. If the goal is to derive x if 8(20+y+x)=0, the equation becomes 160+8x+8y=0. Then we could find y with respect to x in the following manner:
8y + 8x = -160
8y = -160 - 8x
y = (-160 - 8x)/8 <- unsimplified
Then subsitute the y we found back into the equation:
160 + 8y + 8x = 0
Which would become 160 + 8((-160 - 8x)/8) + 8x = 0 and then we could solve for x. The process would be similar if we're solving for y. If it's something else, then I have no clue based on what we know so far.
[This message has been edited by Bullines (edited 06-06-2001).]
That was all the information that was given for the problem on the work sheet. I also came up with 160+8y+8x. If you substitute numbers for the x and y, they equate the same. I had the same problem with my calculator. I'm actually starting to think it was a trick question. it seems to me that the original equation is simplified from the one we have come up with. But I have no real idea!!Its only been 7 years for me since algebra!
8(20+y+x) is not exactly a problem. there must be more information, it has to equal something otherwise its just a statement like 1 + 1 = 2
you cannot set it equal to zero and solve for a variable as mentioned earlier because then the statement is undefined.
[This message has been edited by mbowling (edited 06-06-2001).]
not bad...the one from calculus that i remember uses divergence of sequences and series
ln(1 + x) = x - x 2 / 2 + x 3 / 3 - x 4 / 4 + . . .
Plugging in x = 1:
ln 2 = 1 - 1 / 2 + 1 / 3 - 1 / 4 + 1 / 5 - 1 / 6 + . . .
2 * ln 2 = 2 - 1 + 2 / 3 - 1 / 2 + 2 / 5 - 1 / 3 + . . .
2 * ln 2 = (2 - 1) - 1 / 2 + (2 / 3 - 1 / 3) - 1 / 4 + (2 / 5 - 1 / 5) - . . .
2 * ln 2 = 1 - 1 / 2 + 1 / 3 - 1 / 4 + 1 / 5 - 1 / 6 + . . .
2 * ln 2 = ln 2
2 = 1
there is one with imaginary numbers also, too bad i cant program with imaginary numbers to make imaginary parts...never have any scrap
A small error in the conditions required here Bullines. Let's not lose faith in the laws of mathematics!
(a + B)(a - B) = b(a - B)
a + b = b (where a <> B)
You can only divide both sides by (a-B) if (a-B)<>0. i.e. a condition of a<>b is necesssary - otherwise it blows up. a=b is exactly the case though.
It is 7th grade math class.
couldn't the answer be an ordered pair?
If you set 8(20+y+x) = 0
subtract 160 from both sides 160+8x+8y = 0
divide both by 8 8x+8y = -160
this would be the answer x+y = -20
any 2 numbers that add up to -20 would be the solution for x and y.
what do you think?
Biss03 i see you trying to tell the little one at home the answer after this.
it should be a straihgt forward thoght but after this. son you need to read this thread i don't know any other way to tell you.
jay/ aka cadcam
Precision Programming
cnc programming &
Predator reseller
email: [email protected]
web: www.ppcadcam.com
Mastercam forum FTP free file support
ftp://www.ppcadcam.com
User: mastercam
Pass: forum
bullines is right, an explanation is necessary. you can't set it equal to zero and solve for a VARIABLE. and any two numbers that add up to -20 would make the equation true if it is set to zero. but that could be an infinite series of numbers not an ordered pair. an ordered pair (5,-5)ie. is typically used as a cartesian coordinate.
probably need to know what chapter his math book is dealing with
next week: having fun with derivatives smile.gif
