Mp.master Next Tool Call
robk
I have a 40 tool machine, and need the post to cycle only up to 40, than start at the beginning again. For example... Tool 53 would be posting as 13, Tool 107 would be 27, etc, etc.
I tried the Misc. variables with no luck. Could it be a switch, or maybe a formula??
Let me understand this correct. You want yout tool libary to have 200 tools but when you call tool 200 and you call tool 40 they both output as tool 40 not sure why you are trying to achieve this. I would think that you would have to do a misc with a combintaion with the tool varaible to get the result soemthing like this might work.
If Mi2 = 1 & t > 40 & t < 80,
t = t - 40,
!t
If Mi2 = 1 & t > 80 & t < 120,
t = t - 80
!t
I have not tried this just came up with it as I was typing this response but think it might get you close to what you are looking for.
Ron,
The reason is because we do a lot of production work in here, and all the tool libraries are already created with their tool #'s. I know that it is easy enough to change the tool #'s for that one machine, but I would like to try it with mp.master. Here is the sample from our original custom post.
if t >= 161, t = t - 160
if t >= 81, t = t - 80
if next_tool >= 161, next_tool = next_tool - 160
if next_tool >= 81, next_tool = next_tool - 80
The problem is that I can't figure out where to insert that info into the new post.
That would be where the tool is called in the post in the post blocks. That would be at here in MPMASTER:
ptlchg_com      #Tool change common blocks
pcom_moveb
c_mmlt #Multiple tool subprogram call
#ptoolcomment
comment
pcan
if plane < 0, plane = 0
if stagetool >= zero, pbld, n, *t, "M6", ptoolcomm, e
Then above the line where the *t is you need ot have the equation above this so when the post output the data you get the correct output you are looking for hope that helps.
