Defining stock
Mgrenier
Hello all,
I have to program a part that was previously cut on a lathe with a taper surface on top. I would like to know if there is a way of telling MCAM mill to use a MC9, STL of whatever format file as my stock?
The lathe part was not programmed in MCAM but I do have the DWG of the file after lathe machining.
Thanks for your help,
Thanks guys,
I can do that, but I do not see how I can use that STL file as my stock definition for the toolpaths that I have to start cutting from.
You see, a have a tapered surface for the top of my stock (2" taper) and I need to plunge mill some open pockets. I want to avoid cutting air by starting my cutter .100" from the top surface, not .100" from te top point of my surface.
Hope the question is clear enough...
