Egg-Shaped Holes Revisited
dxclark
A recent post (http://www.emastercam.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=000457) complained of egg-shaped holes. The general response suggested machine deficiencies as the most probable cause.
Please review the following code that mastercam puked out for me:
N10 O0000 (MC811-TEST )
N20 G0 G90 G80 G70 G40 G17
N30 T1 M6 ( 1/4 FLAT ENDMILL )
N40 G0 G90 S6000 M3 E1 X.215 Y0.
N50 G43 H1 D1 Z.25 M8
N60 Z.1
N70 G1 Z-.1 F6.
N80 G2 X-.2149 I-.215
N90 X.215 I.215
N100 G0 Z.25
N110 M5 M9
N120 T1 M6
N130 M30
Please note line #N80:
This is junk code on any machine!
I will try to ftp these files for further review.
MC811-TEST.MC8
MC811-TEST.NC
Looks like a Fadal format? What is the tolerance of the machine for the start point and arc center before it alarms out? How are you measuring the hole roundness?
What was the measured results? We are talking a tenth here. depends on the geometry that was created, And if the post has been modified.
Alot of factors here to look at.
Looks like boring head teritory.
When I recreated this in MC8, it posted just fine.
>N90 X.215 I.215
Umm..I disagree. This code is perfect on almost any machine. Y0 is going to be modal and I or J = 0 should never need to be output. If the issue is with the .2149, apparently the arc center is not exactly at X0Y0, or the radius is .21495 or some such, and rounding inside the post is throwing off the I's and J's. There is no better output available unless you can program to 5 decimal places.
If you need tighter arc center tolerance, cut the part in metric (.001 mm = .000039 in)
For your own peace of mind, just totally eliminate Mastercam as the problem.
Manually program a 1.0 diameter hole using one of the examples in the Fadal manual as a guide.
Put a dial indicator in the spindle and spin it. My guess is the hole will be elliptical. Time to call Service...
If the post is wrong, you might get an error at on the control, you may even skip part of the arc, but highly unlikely you'd ever get an oval.
Thanks to all responents.
However, this is not a machine problem!
My machine makes perfectly acceptable circles when properly programmed to do so.
i.e. either 360 degree arcs or 2 - 180 degree arcs properly coded.
Please do not dismiss the .0001 error as insignificant until you have posted this to your machine.
Will any of you please send the faulty code I have described to your machine and describe the measured results.
I know you, like me , are too busy to tie-up a valuable machine tool and spend the time necessary to test this on a whim, but I am convinced (from actual practice) that the resultant part will be found unacceptable.
Thanks again.
Dxclark
I checked out your file. I analyzed the arc. The center of the arc is currently X.00004 Y0. When I posted it this way using the mpfan post I got the same result. But when I edited the arc center to be X0 Y0, the problem went away. Try changing the center of the arc and reposting. Good luck.
mlindsey,
You're correct. The sample MC8 file was contrived like this intentionally to reflect a real-world condition that recently occurred.
My customers send solid models to me and I have to use them to create my tool paths. It is not practical (nor should it be necessary) to amend their geometry to accomodate mastercam.
Wait a minute.... I've never known Mastercam to incorrectly round a number. If the last digit behind that displayed is 5 or greater, it rounds up. If less, it rounds down. That's how I'd do it too if I were writing the code by hand.
Basically, we're going to machine what the engineer draws. The databases are double precision, so there should be no roundoff errors in the data translation, or resulting from however we rotate, translate, etc.
Maybe I'm missing something here. Is there really some situation (once in a blue moon) that you can get into that you'd round otherwise because you know they intended an arc when but drew it "wrong"? Wouldn't this manifest itself in some other way, like a discontinuity between entities?
[ 08-06-2001: Message edited by: Charles Davis ]
Millturn,
Sorry, I did not mean to imply that the circles are "perfect", only "perfectly acceptable".
i.e. within +/- .0005 on diameter in this instance. The actual error from my example produced an error approaching .005 dimensionally on my VMC.
Charles Davis,
A "rounding error" does not suggest an algorithmic error, but rather an error in fact!
The "rounded" portion of a number may have a deviation from the original number. This does produce a mathematical error. This error is evident in the sample code I provided.
I talked about this with Marc Lindsey late this afternoon. I understand the problem more now. This is an odd one!
His idea was to truncate the number rather than round it; he's looking into it.
Another idea we had was to break the arcs into quadrants, rather than 180 degree arcs (yuk).
I THINK v9 will output 360 degree arcs.
Charles Davis,
Thank you!
I was starting feel like "one against the world"! Although the sample I provided was contrived, to be sure, it was based on a customer's model. The "error" occurred twice in this one part. Once as a boss (like my example), and once as a hole.
I am not looking to find a "work-around". The program in question was already modified (by using 5 decimals of precision) and the parts were shipped.
I simply wanted to make public what I perceive as a flaw in this $**,*** program that I paid for.
Thanks again,
Dan
I believe that if you add a J0 to the offending line (N80) you will solve your problem.
This is a common problem with many controls. They will 'fit' the arc to the endpoints unless forced to do otherwise.
To simulate what the control goes through, draw points at -.9999,0 and .9999,0 and then
create
arcs
endpoints
with a 1.0 inch radius, using the points.
When you analyze the arc center you will see a substantial error. This usually occurs with programs written using "R" values near 180 degrees. I will also occur if the control does not assume J0 for the unsupplied value.
I've been here before - for years.
Craig Madsen
[email protected]
Hi Charles Davis,
For Mastercam around correcly:
This is definition the C++ not Mastercam.
But, Mastercam is write in C++.
Wallace M. Jr.
São Paulo - Brazil
I have experienced a simular problem which was easily solved by changeing the way the post outputs the arc. Many controls can accept arcs in diferent ways. It is my guess that the post outputs the information in an arc-rad format. The failsafe change is to change the output to an I,J format.
Hey there,
I have been down that egg shape hole road before .
In order for me to fix it ,I had to reset my controller's parameters from "Read circle from center point to read circle from endpoint" or vice versa...I forget.
I use in "Job setup" a seperate feed rate for arc's.
I am within .0005 good enough.....
[ 08-17-2001: Message edited by: Tony ]
Toby,
I agree, that is hilarious. I didn't really look at it until you pointed it out. I never knoew Mastercam could puke. I wonder if I can get it to hurl something out, no, no, on second though that might not be such a good idea.
