another post question
notso
Since you guys are volunteering all of this cool post editing info. I have a question for ya.
When I try to use Canned text to put an M00 in the program that's all I get (no retract, spindle stop etc).
I would like it to give me that stuff before the M00 and I would like it to give the start up commands afterwards.
With the mpfun.pst:
Find pcant_out
ther will be sumthin like
if cantext = one, strcantext = strcantext + sm00
you can:
if cantext = one,[
"ADD STUFF HERE",e
"M00",e
"ADD MORE STUFF",e
If your not sure what value of cantext your on you can temporarily add:
~cantext,"HHHHHHEEEEERRRRREEEEEEEE",e
to the top of the pcant_out post block to out the value. the extended heere is to help find in nc output.
Try hard coding it in ptlchg:
from MpHaas:
ptlchg #Tool change
"G91G28Z0.", e
"G90M05", e
"M00", e
pcuttype
toolchng = one
# if mi1 = one, #Work coordinate system
# pfbld, n, *sg28ref, "X0.", "Y0.", e
# pfbld, n, "G92", *xh, *yh, *zh, e
# pbld, n, "M01", e
pcom_moveb
c_mmlt #Multiple tool subprogram call
ptoolcomment
comment
pcan
pbld, n, *t, "M6", e
pindex
sav_absinc = absinc
if mi1 > one, absinc = zero
pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout,
pcout, *speed, *spindle, pgear, strcantext, e
pbld, n, "G43", *tlngno, pfzout, next_tool, e
pbld, n, scoolant
absinc = sav_absinc
pcom_movea
toolchng = zero
c_msng #Single tool subprogram call
This way you will always get the code at every tool change.
if you want it only when you need it try using your own routine tied to a variable like mi3
again from MpHaas:
p_m0000 #My M00 routine
"G91G28Z0.", e
"G90M05", e
"M00", e
ptlchg #Tool change
if mi3 = 1, p_m0000
pcuttype
toolchng = one
pbld, n, "M01", e
cp
There are a lot of ways to handle this. Below is an example where the misc values page is used instead of canned text. This method will also automatically force a toolcahnge in examples where the same tool is used for the next operation.
ptlchg0 #Call from NCI null tool change
if (op_id <> prv_op_id) & (mi1 = 99),
pretract
ptlchg
else,
Below this bracket, include everything that is currently in ptlchg0 and close with a bracket.
then modify in "ptlchg" to look like this:
if mi1 = 99,
n, "G28", "Y0", e
n, sgabsinc, e
n, "M00", "(PROGRAM STOP)", e
else,
n, sgabsinc, e
n, "M01", e
I also copied this post for the Haas Mill to the FTP site "Mill_Haas_VF.PST/TXT". This post includes several Haas specific features like the IJK drilling, reverse rate for Tap, peck tapping, and a feature to move to specified location for tool change. This last feature is very helpful if you work with tall parts.
Or you could always use "Force Tool Change" Located by clicking the "Change NCI" button on the Tool Parameters Page of any Toolpath where a tool is to be selected. :shrug: If you uhave multiple depth cuts in the toolpath you're trying to force the change in, you could end up with a tool change at every depth cut, but for other toolpaths, it works slick as a whistle. It used to not be an issue but SOMEBODY at CNC broke it in V9 and didn't fix it. :sad:
HTH the cause.
