problem with 3d operation
Hi
can any one help me solving the problem below
( I draw a solid form in the autocad then I converted it to IGES file to import it to mastercam then I strted to make an operation but while analysing it gives me a massage says ( want to change the color of last processsd surface ? )when I choose ok mastercam gives me the color table to choose from then the analysing stopes and if I choose no the analysing just stopes what can I do
the links of the operation file and the video file is below:
http://www.x111x.com/File/1123252089.zip
http://www.haascnc.com/news/new_files/VMC/...Mini%20Mill.wmv
thanks
Salem, I don't know why you are having problems with this file. I read it in O.K., analyzed the surfaces no probleb, and just hit regenerate toolpaths. seemed to work fine. I put Salem_1.zip up on Cadcams ftp site with the toolpaths. Hope this helps
Steve
thanks steve
do you mean regen path if yes that means that I have unknown problem because this screen facing me and if I choose yes the color table appears- after choosing the color - no thing happens and still MC could not genrate the tool path
if I choose no I face the same problem with out the color table
wait for the image ...
thank you
Hey Salem,
I too downloaded your file, analyzed it, regen toolpath and all is well. Until I tried it again, the regen works fine until I hit the esc button on the keyboard. Then I get the same error you did. So I tried it again not hitting the Esc on the keyboard and all worked well again.
Do you have something hitting your Esc button on the keyboard when trying to regen? headscratch.gif
Pick a color not used in your drawing, then do an "Alt E" "all" "color" and pick the same color you just picked. The problem surface should be the only thing on your screen. Some times they are really small surfaces that are hard to see. Check all views Top, front, side, ect.... if you still can't see the surface try the screen statistic and it should tell you if there is a surface there. Sometimes thay will appear if you unshade also.
After you find the problem surface you may have to make it over,or delete and not use it if is really small, then try to regenerate the tool path.
Hope this make sense
hey mold100 it looks the happened to you , I just changed the tolerance from 0.25 to 1.0 and it work directly so thank you
thank you midwest but I still didn't use your idea yet
when I use it I show you the result
sorry people but I still have a Q. !!!
how did the operation works with others ?!!
thank you all !!!!!!!!!...........
