No feed with drill cycle X
DaveR
I'm getting a 0 feed rate in my posted code with my drill cycles.
N14500 G81 G99 X9. Y-2.4713 Z-.4 R.1 F0.
I specified 10 ipm, 20 ipm does not matter. I can change the feed rate but the plunge rate is greyed out for the drill parameters.
I'm also getting a .err file the same name as my posted code when I post a program. I can't open it so I have no idea what is in there.
Any ideas where to look to fix this issue?
03 Sep 2005 03:05:00 PM - <0> - Report created.
03 Sep 2005 03:05:00 PM - <2> - Initialize posting log file
03 Sep 2005 03:05:00 PM - <2> - Using MP run version 10.00 and post components version 10.00
03 Sep 2005 03:05:00 PM - <2> - Initiate opening the post processor file(s).
03 Sep 2005 03:05:00 PM - <2> - Post processor file name: C:MCAMXMILLPOSTSMPMASTER_FADALCNC.PST
03 Sep 2005 03:05:00 PM - <2> - The post processor file has been successfully opened.
03 Sep 2005 03:05:00 PM - <2> - The post processor file has finished the read process.
03 Sep 2005 03:05:00 PM - <2> - Post version information (input):
03 Sep 2005 03:05:00 PM - <2> - UPDATEPOST Version 10. was used to modify this file.
03 Sep 2005 03:05:00 PM - <2> - The file was modified by this product on 15 Aug 05 17:10:02
03 Sep 2005 03:05:00 PM - <2> - The post was written to run with Mastercam Version 10.
03 Sep 2005 03:05:00 PM - <2> - The post product type is Mill.
03 Sep 2005 03:05:00 PM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
03 Sep 2005 03:05:00 PM - <2> - Search for defined post variables, strings, postblocks was successful.
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'met_mtol$' was re-initialized from 0.000001 to 0.001
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'met_ltol$' was re-initialized from 0.002 to 0.01
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'dec_seq_left$' was re-initialized from 3. to 0.
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'tplanemode$' was re-initialized from 2. to 1.
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed5$' was re-initialized from 1. to 0.
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'lrotfeed5$' was re-initialized from 1. to 0.
03 Sep 2005 03:05:03 PM - <2> - CONTROL DEFINITION - - Post variable 'peckacel$' was re-initialized from 0. to 0.51
03 Sep 2005 03:05:03 PM - <2> - Successful completion of posting process!
This is the file that gets output as a seperate file with label .err. No big deal, I just delete it but why is it being output and can I turn it off?
DaveR,
To limit the err files.
Go into
control.def>files>
go to the "posting error file" section
change keep error file "On fatal errors"
Message option "All error messages to screen"
Then you should only see them when something goes terribly wrong.
my guess is that you are picking a solid. I have the same issue. Create a point or edge curve & pick that.
Having the same problem here.
Anyone figured out a fix for that, or is CNC Software working on it ?
Mark
