Hyperthreaded P4 2.8 overheating when Mastercam running
Conrad K.
I've been supporting a tool-making shop that has been using Mastercam for many years. Currently they're on 9.2, and I've been supporting them since 7.0 so we've been around the block a few years. My expertise is hardware & software not CAD/CAM.
Just upgraded the design machine to a P4 2.8ghz hyperthreaded, 1gb of RAM, lots of bells & whistles. The CPU is running the recommended fan and is Intel made & sold. I might add, that I'm having the same problem with a P4 3.4ghz so it's not just this machine.
Here's the problem. The machine will run perfectly normally with a CPU temperature holding constant at 55deg Celsius, with the fan turning at 2500rpm. No problem.
The instant Mastercam is loaded, the CPU temperature goes to 80deg C, bells & whistles go off, the fan revs to 3800rpm ready for takeoff and never comes back down, all in less than 2 minutes.
The instant we close Mastercam, less than 45 seconds, back down to normal.
I've always know that Mastercam is a CPU hog but this seems just a tad excessive, aside from being hot enough to fry eggs.
What have I missed, or is this just the way it is? I have ordered a larger CPU fan, but we're almost at the top with the one we have!
SOmething else, I run a Laptop with a P4 3.4 GHz w/ HT. When running V9 and previous, I try to leave a WIndows Dialog Box open when at all possible (Solids Manager, Operations Manager, Level Manager, etc...) this keeps things cooler. I run ALL my toolpaths out of the Operations Manager to help things along also.
In my laptop, I can't seem to be able to turn off the HT. So far it's not been a problem for me.
A CPU hog is probably an understatement. As has been said many times on the forum, Mcam 9 basically uses the entire CPU while it is running. I used to run into this same problem with OpenGL screensavers on windows a few years ago. When the monitior on my server flipped to a screensaver it killed the network performance...took a while to figure that one out....Regardless with the price of gas this year your winter heating bills will be smaller...gets a little chilly just open up another instance of Mcam 9
I don't think this is true.
I frequently run V9, Solidworks, Predator VCNC
Cimco Edit and Windows Explorer all at the same time.
That would not be possible if V9 was using 100%
of the CPU. The fans do run all the time under these conditions though biggrin.gif
