TOOL LIST
MCFELIX
Hi Felix!
Welcome to the forum! Anyway, if you use the mpmasterpost, your tool list will come up at the beginning of your program. You can download mp master post from the "posts" page at the top of this page.
BTW, if you type in caps, people think you're shouting at them.
hope this helps!!
Mike R.
[ 12-17-2001: Message edited by: Michael Reynolds ]
To get the MPFAN.PST (from the v8.1.1 CD) to output a list of the tools
used in the program to output at the start of the NC file ->
First, you must tell the PST to do a pre-scan of the NCI file.
Add this varaible to the MPFAN.PST ->>
tooltable : 1 #Do a pre-scan of the NCI (calls postblock 'PWRTT')
Now you need to add the PWRTT postblock that will be called because
of the 'tooltable' setting. We will just have this call the PTOOLCOMMENT
postblock that already exists in the PST.
pwrtt # Called at each toolchange (and NULL toolchange) in the program
if t > 0, ptoolcomment # Only do if T > 0 (at a real toolchange)
Note that the tool list will output PRIOR to the '%' at the start of the NC file.
If you wish to reposition the tool list so that it outputs after the initial NC startup
blocks, you would relocate the startup blocks. Move them from PSOF and
place them into the PHEADER postblock.
pheader #Call before start of file
if met_tool = one, #Metric constants and variable adjustments
ltol = ltol_m
vtol = vtol_m
maxfeedpm = maxfeedpm_m
# Start of NC file.... following lines relocated from PSOF postblock ->>
"%", e
*progno, e
"(PROGRAM NAME - ", progname, ")", e
"(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e
The result in output such as ->
O1234
(PROGRAM NAME - MTEST)
(DATE=DD-MM-YY - 17-12-01 TIME=HH:MM - 10:27)
(1/4 FLAT ENDMILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .25)
(5/16 FLAT ENDMILL TOOL - 4 DIA. OFF. - 4 LEN. - 4 DIA. - .3125)
(3/8 DRILL TOOL - 3 DIA. OFF. - 3 LEN. - 3 DIA. - .375)
(1/4 CENTERDRILL TOOL - 5 DIA. OFF. - 5 LEN. - 5 DIA. - .25)
N100G20
N102G0G17G40G49G80G90
Mpmaster is my own 'child' of Mpfan. It has some additions to tackle commonly requested post functionality - like a tool table for instance.
We use it here at In-House to as a starting point for 3/4-Axis machines with somewhat standard G-Code.
Mpfan is CNC Software's flagship post, and certainly can be modified to cover more than just Fanuc controls. It's been my experience that starting with a solid post and modifying it to suit saves time and headaches in the long run.
I've found I can get ALOT more accomplished starting from MPFAN or MPMASTER. Both are excellent places to start IMHO. They have most all the logic you'd even need for 3-4 axis machine. They don't have everything but, they certainly come close.
JM2C
I agree, I started with mp ez post for use on simple 3 axis generic fanuc controllers, and found it to be FLAWLESS. Then when using our 4th axis horizontal fanuc, MPfanpost worked good with a few modifications. THEN, I started using MP masterpost for the 4th axis stuff (and sub programming), and will not go back (unless I'm programming for a simple 3 axis VMC.
Mike R.
