Coolant - Air blow
kccadcam
Back again,,,,
Mpmaster for X MR1/SP2 and above. It's our master configurable 4-Axis G-Code post. Rotary settings are configured in the Machine Definition.
Configuring Matsuura H600 cell post.
I have created:
#( COOLANT AIRBLOW COMMANDS )======================================
ptool_airblast
n$, "M52", "(AIR BLAST ON)" ,e$
n$, "G4 X9.5" ,e$
n$, "M53", "(AIR BLAST OFF)" ,e$
I,m trying to insert:
---> if prv_coolant$ = 3, ptool_airblast <---
into pretract when coolant-tool is shut off.
Cannot get it recognize prv_coolant??
I think it is conflicting with the new x-coolant stuff....
Anybody care to steer me in the right direction??
Here is my pretract:
 pretract        #End of tool path, toolchange
sav_absinc = absinc$
absinc$ = one
sav_coolant = coolant$
coolant$ = zero
# if nextop$ = 1003, #Uncomment this line to leave coolant on until eof unless
# [ # explicitely turned off through a canned text edit
if all_cool_off,
#all coolant off with a single off code here
if coolant_on, pbld, n$, *sall_cool_off, e$
coolant_on = zero
else,
local_int = zero
coolantx = zero
while local_int < 20,
coolantx = and(2^local_int, coolant_on)
local_int = local_int + one
if coolantx > zero,
coolantx = local_int
pbld, n$, scoolantx, e$
coolantx = zero
coolant_on = zero
#cc_pos is reset in the toolchange here
cc_pos$ = zero
if convert_rpd$ = 1,
gcode$ = 1
feed = maxfeedpm
ipr_type = 0
else, gcode$ = zero
pbld, n$, sccomp, *sm05, psub_end_mny, e$
pbld, n$, sgabsinc, sgcode, "G28", "Z0.", [if gcode$ = 1, `feed], scoolant, e$
#if lock_codes = one & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
#pbld, n$, "G28", "X0.", "Y0.", protretinc, e$
#if lock_codes = one & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
if abs(fmtrnd(cabs)) > 360 & nextop$ <> 1003,
if lock_codes = one, pbld, n$, *sunlock, e$
rotretflg = 1
pbld, n$, 'G28', protretinc, e$
rotretflg = 0
if lock_codes = one & cuttype = 0, pbld, n$, *slock, e$
absinc$ = sav_absinc
coolant$ = sav_coolant
"G49", e$
pbreak, e$
How about trying this instead.
It looks like you are trying to create a post block why not just handle it in the pretract section like so. Insert this after the off coolant call.
n$, "G4 X9.5" ,e$
Are you sure its not seeing the if prv_coolant$
and is not picking up the post block instead?
n$, "G4 X9.5" ,e$
That's exactly what I started with....
I cannot get it to accept the prv_ command.
If I say:
 if coolant$ = 3
it will output on the previous tool....
Stumped...........
Dumb question,
Is the prv_coolant$ being set immediately after the coolant call in the ptlchg sections?
Then after it's used at the end of the pretract section you might want to zero it back out just for s/g's
Can you post the section where the prv_coolant is being set?
I don't know much about the new coolant stuff... but you can try this in the ptoolend postblock;
ptoolend$        #End of tool path, before reading new tool data
!speed, !spdir2
if nextop$ = 1002,
n$, "G4 X9.5" ,e$
This is from the end of ptlchg_com:
 if nexttool = first_tool$,
pbld, n$, "G43", *tlngno$, pfzout, scoolant,[if coolant$ = 3,"(HP COOLANT)"], "T0", e$
else, pbld, n$, "G43", *tlngno$, pfzout, scoolant,[if coolant$ = 3,"(HP COOLANT)"], next_tool$, e$
if coolant$ = 1, sm09 = sm09_0
if coolant$ = 2, sm09 = sm09_1
if coolant$ = 3, sm09 = sm09_2
pcom_movea
toolchng = zero
c_msng$ #Single tool subprogram call
plast
this is my current pretract:
absinc$ = one
coolant$ = zero
if all_cool_off,
coolant_on = zero
else,
local_int = zero
coolantx = zero
if coolantx > zero,
coolantx = zero
coolant_on = zero
cc_pos$ = zero
gcode$ = 1
feed = maxfeedpm
ipr_type = 0
else, gcode$ = zero
rotretflg = 1
rotretflg = 0
if prv_coolant$ = 3, <----------NEW
n$, "G4 X9.5" ,e$
"G49", e$
pbreak, e$
Is prv_coolant$ a varaiable you created?
If so, try dropping the $ at the end of it.
Also , where is it set?
somewhere there should be
prv_coolant = coolant$
long way of doing it but I got it to work..thanks for the idea.
absinc$ = one
coolant$ = zero
peck1$ = zero
cc_pos$ = zero
gcode$ = zero
pbld, n$, sgabsinc, sgcode, *sg28ref, "Z0.", scoolant, e$
ptool_airblast #KC addon
else,
coolant$ = zero
peck1$ = zero
cc_pos$ = zero
gcode$ = zero
