Posting HAAS WCS G110 as default
I am trying to set up a post for a HAAS, it uses G110 and up. I am trying to make it so the default (-1) begins at 110.
I am scratching my head however, if I change the offset to 0, starting there I get G110 on up but when I use the default setting I keep getting G116, I cannot for the life of me figure out where it is picking up the number.
Where does the post draw the variable from when the workofs$ is set to -1?
It's pretty stock with the one obvious change
pwcs            #G54+ coordinate setting at toolchange
if wcstype = two | wcstype > three,
sav_frc_wcs = force_wcs
if sub_level$, force_wcs = zero
if workofs$ <> prv_workofs$ | (force_wcs & toolchng),
if workofs$ < 6,
g_wcs = workofs$ + 110
else,
if workofs$ >= 0 & workofs$ <= 25, *g_wcs
else,
if mprint(swcserror, 2) = 2, exitpost$
force_wcs = sav_frc_wcs
!workofs$
G00 G90 G49 H13 S4500 M03
M08
workofs$ 6.
G116 G00 G43 X-1.3856 Y.666 Z2.
I can't isolate using if workofs$ = 6 or anything because when a hand typed 6 might get used, it will have the same reaction as the default setting.
I figured it out.
I use this file for different post testing and I had the offest set in the WCS manager to 6, that's why it was coming out the way it was.
I changed it to -1 and all was as I expected to get.
[ 08-06-2006, 06:20 PM: Message edited by: John Paris @ Kevlin ]
Hey John Try this.
    pwcs            #110+ coordinate setting at toolchange
if workofs$ < 25,
else,
!workofs$
Not sure what it will do but I would do away with from the (else) there. Glad you got it but I would look at having my post this way if you are going to use G110 and greater.
Here is what I did in a MPMASTER V9 post for the HAAS where I was using the G154 PXX so from what I remember G110 is G154 P1 and when you get to G126 it becomes G154 P26 but could be wrong has been a couple years since working on the HAAS with these capabilites.
if sub_level, force_wcs = zero
if sav_mi9 = 1, workofs = sav_workofs
if workofs < 0, workofs = 0
if workofs <> prv_workofs | (force_wcs & toolchng),
p_wcs = workofs
"G154.1", *p_wcs
!workofs
