help? (on post switch/boolean)
kinglouie V
I'm trying to force a "W0" to limit motion on quill and not column. right now I'm working on the move going "home". not working out so good.
I can get the normal "Z0" and I can get both "W0" and "Z0" but can't switch between the two like I want. see below if interested.
N820 M5                                 ptlchg1002$ p__9:928 872.$
N830 G91 G28 Z0. M9 ptlchg1002$ p__9:928 872.$
N840 G28 Y0. ptlchg1002$ p__9:928 872.$
N850 M5 ptlchg1002$ p__25:1063 872.$
N860 G0 G90 G54 G49 G80 W0 M9 ptlchg1002$ p__25:1063 872.$
N870 G91 G28 X0. Y0. ptlchg1002$ p__25:1063 872.$
N880 M00
post........
 ptlchg1002$      #Call at actual toolchange, end last path here
if op_id$ <> prv_op_id$, pset_mach #Set rotary switches by reading machine def parameters
if cuttype <> one, sav_rev = rev #Axis Sub does not update to rev
pspindle
whatline$ = four #Required for vector toolpaths
if gcode$ = 1000,
#Null toolchange
else,
#Toolchange and Start of file
if gcode$ = 1002,
#Actual toolchange
pretract
else,
#Quill motion only at toolchange
if mi4$ = 1,
pbld, n$, sccomp, *sm05, psub_end_mny, e$
pbld, n$, *sgcode,*sgabsinc, *g_wcs, "G49", "G80", "W0", "M9", e$
pbld, n$, "G91", *sg28ref, "X0.", "Y0.", e$
absinc$ = sav_absinc
coolant$ = sav_coolant
if stagetool = one, prv_next_tool$ = m_one
prv_xia = vequ(xh$)
prv_feed = c9k
!op_id$
Lou,
Try your changes in ptoolend;
ptoolend$        #End of tool path, before reading new tool data
!speed, !spdir2
if nextop$ = 1002,
if mi4$ = 1,
is there a general "rule of thumb" I can look up?
If you are refering to "[ ]", every "[" needs a "]", also if you are not doing so Indent all of your "[" a few spaces, then when you close them, line it up vertically, it will make it much easier to follow, I have to do that plus add extra blank lines so all the "logic" looks kinda like a arrow pointing to the right, even then I usually end up with a headache and mumbling things to my self.
Jg
Did you use "if nextop$ = 1002"? If you copy from the previous posting if should work just fine. Here's how the post I copied from looks;
!speed, !spdir2
if nextop$ = 1000, prvtpsub = virt_tlplnno
if mi8$ = 1, pbld, n$, "G69", e$
pbld, n$, sgplane, e$
if nextop$ = 1002,
prvtpsub = 0
plane$ = 0
psub_end_s$
subout$ = 0 #main NC program
procesreturn, e$
pcoolantoff
sav_mac_tloffno = 0
sav_mi6 = 0
You can create your own pretract and configure it how you want;
if op_id$ <> last_op_id,
#if cuttype <> one, sav_rev = rev #Axis Sub does not update to rev # CNC Mpfan V9.1
if one_rev = one | workofs$ <> prv_workofs$, sav_rev = 0
pspindle
if gcode$ = 1000,
#Null toolchange
else,
if gcode$ = 1002,
#Actual toolchange
if mi4$ = 1, p_mi4_pretract #<<<<<<<<<<<<<
else, pretract #<<<<<<<<<<<<<<<<<<<<<<<
prv_xia = vequ(xh$)
prv_feed = c9k
One of the reasons that I think MC posts just blow away the NX stuff that I have done.
If you can think it you can likely, fairly easily, sometimes, code and customize it.
