to post gurus
mig
Hi,
This is part of Code from my post for okuma.
(PROGRAM MAX: Z.25")
(PROGRAM MIN: Z-1.98")
N1
M1
€€€€(OPERATION MAX: Z= .25")
(OPERATION MIN: Z= -1.98")
(STOCK: XY= 0.|Z= 0.)
got some strange symbols which I can’t take off,
Anybody new what this is and how I can take them off?
Regards
Seems to me there is likely some ascii number or a number that creates that symbol that is erroneous in the post.
Never seen it before.
Run the post debug on and find out where that is being output from and then look in that section in the post.
Post Debug
control def >> nc output >> debugging box checked
I'd guess whatever it is will be rather obvious.
Did you write that
in the "Toolchange / NC output Variable Formats" section of your post?
search in your post for something like this
fmt X 2 x_tmin # Total x_min
fmt X 2 x_tmax # Total x_max
fmt Y 2 y_tmin # Total y_min
fmt Y 2 y_tmax # Total y_max
fmt Z 2 z_tmin # Total z_min
fmt Z 2 z_tmax # Total z_max
fmt Z 2 min_depth # Tool z_min
fmt Z 2 max_depth # Tool z_max
and post it here.
Hi john316,
Here you are :
fmt "Z= " 2 min_depth # Tool z_min
fmt "Z= " 2 max_depth # Tool z_max
I don't know if the "Z= " has anything to do with it, but these are format statements and are used to format the post output. Take those out and try posting again.
The "Z= " statements can be set-up in psof$
if output_z = yes$ & tcnt > 1,
"(OVERALL MAX ", "Z= ", *z_tmax, ")", e$
"(OVERALL MIN ", "Z= ", *z_tmin, ")", e$
Correction, set up your "Z= " statement in ptlchg_com
n$, pspc, "(", "MAX=", "Z= ", *max_depth, ")", e$
n$, pspc, "(", "MIN=", "Z= ", *min_depth, ")", e$
The string your using uses the *max_depth and *min_depth coomands. It looks like you changed the MAX and MIN text to OPERATION MAX and OPERATION MIN.
Looks like "preadbuf5" cause this problem,
If I deleting this word problem disappearing, but I loosing min ,max numbers also.
Anybody know what this command does? And where is this buffer5 ?
My converted from v9 post also has this word, but working fine only match slower
Mig,
Mail
Yes deleting that will cause a problem if you are looking to get the information it provides.
This is buffer 5
# Buffer 5 Read / Write Routines
pwritbuf5 # Write Buffer 1
b5_gcode = gcode$
b5_zmin = z_min$
b5_zmax = z_max$
b5_gcode = wbuf(5, wc5)
preadbuf5 # Read Buffer 1
size5 = rbuf(5,0)
b5_gcode = 1000
min_depth = 99999
max_depth = -99999
while rc5 <= size5 & b5_gcode = 1000,
if rc5 <= size5, b5_gcode = rbuf(5,rc5)
if b5_zmin < min_depth, min_depth = b5_zmin
if b5_zmax > max_depth, max_depth = b5_zmax
It can be found near the bottom of the post
It collects all of the depth information about your toolpaths and outputs it with the appropriate tool
