Custom Drill cycle
gcode
I would like to deveolop a custom drill cycle
to spot holes at one feedrate, then finish
at a second feedrate.
The gcode would look like this
G0 X1.25 Y1.25 (rapid to hole location)
Z.05 (rapid to R plane)
G1Z-.25 F3.0 (spot hole at reduced feedrate)
Z-1.305 F9.0 (drill hole at normal feed rate)
G0Z.05 (rapid back to R plane)
Ideally, the spotting depth and feed rate could
be set in the fields available in custom drill
They could also be hard coded as a percentage
of programmed feedrate and drill point depth
I currently do this with point toolpath and then
use the Toolpath Editor to change the feedrate
Its very time consuming and prone to errors, so much so, that its not practical for multiple holes.
Can anyone set me on the right path towards building a custom drill cycle?
Something like this should get you on the way
pdrlcommonb
if drillcyc = 10,
depth2 = peckclr$
feed2 = retr$
rpd_hght = refht$
pcan1, e$
pbld, n$, sg01, pdrlxy, depth2, feed2, e$
pbld, n$, pzout, feed, e$
pbld, n$, rpd_hght, e$
pcom_movea
Define the variables needed, feed2, depth2 & rpd_hght
Down in the text section add it like this
[drill cycle 10]
1. "Special"
2. ""
3. ""
4. ""
5. ""
6. ""
7. ""
8. ""
9. "spot depth"
10. "spot feed"
11. ""
The you won't have to use the cutom parameters, you can keep it on the main drilling page
It output this
N100 G00 G17 G20 G40 G80 G90
N110 T1 M06 ( 1/2 SPOTDRILL)
N120 (MAX - Z2.)
N130 (MIN - Z-1.1)
N140 G00 G54 X-.6398 Y.6529 S534 M03
N150 G43 H1 Z2.
N160 G01 Z-.25 F5.
N170 Z-1.1 F10.
You can add the code to the pdlcst2 section to get it to do multiple holes
I know this isn't the solution you were looking for, just another way to skin the cat, but could you spot all the holes first at the reduced feedrate in one drill cycle then go back with another drill cycle and drill them through to finished depth at the faster feedrate?
Also, does your control support overide feed rates and distances, like I and J within your drill cycles? Maybe that way you could just add some misc values to your post? I'm not good with posts, mind you. Then the output migh look like this:
G82 G99 X1.25 Y1.25 Z-1.305 R.05 I1.055 J300. F3.
I being the overide distance and J being the feedrate overide percentage for that distance.
