parameters
gary dunn
have any of you guys been able to get the post processor to pull out any parameters such as
10010 and 10068, etc. i've tried everything in the book and can't get it to work. MPMaster
does it but i haven't been able to figure out why.
it has to be something small that i am missing
but it just hasn't dawned on me yet.
Hi,
Well Gary, I can tell you what I did for the posts we have down here: First you gotta build your parameters tables like such:
# Parameter Tables
fprmtbl 4 1 # Pocket
10350 pocketcomp
fprmtbl 13 2 # Multisurf Finish
10010 stock # Amount of stock to leave on drive surfs
10227 check # Amount of stock to leave on check surfs
fprmtbl 14 2 # Multisurf Rough
Then yous need to go on the pparameter section of the post and add your operation code in there like that:
pparameter # Run parameter table
if opcode = 4 | opcode=13 | opcode=14, result = fprm (opcode).
Hope this will help you. P.S. I am using a Mpmaster derivative.
did all that, and then added "stock test ", *stock down in there and the answer is always 0.
it's gotta be something i'm missing. maybe the
place i put it in the processor.
the pparameter is the first thing it hits in the
post block area, the fprmtbl is right after the opcode stuff, stock is defined and formatted, along with result. and the numbered questions are at the bottom ...
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? y
etc. it just isn't reading it.
Hello Gary,
I forgot to add that for my stock, I also have this post block in my post processor:
pstock # Comment amount of stock to leave
spaces=0
if (opcode=13 | opcode=14), pbld, n," ", pspc, "(TOOLPATH - ", *stoper, ")", e
if (opcode=13 | opcode=14), pbld, n," ", pspc, "(STOCK LEFT ON DRIVE SURFS = ", *stock, ")", e
if (opcode=13 | opcode=14) & check<>0, pbld, n," ", pspc, "(STOCK LEFT ON CHECK SURFS = ", *check, ")", e
spaces=sav_spc
And in the post I add the pstock where I want to output these lines (in the psof post block in my case).
Hope this helps you further more
