post processor modification - coolant
Bob W.
How would I modify my post to shut off the coolant before the spindle retracts (in Z) for a tool change or at the end of a program? Currently the spindle retracts and shuts off the coolant just before the tool change. It retains a little residual pressure during the tool change. My mill is a Haas VF2.
Bob
That appears to post it as it has been. Here is an example:
N1930 G1 G40 X.0371 Y.1923
N1940 Z-.3724 F50.
N1950 G0 Z.1
N1960 M5
N1970 G91 G28 Z0. M9
N1980 M01
( 0.375" - .06R BULL MILL TOOL - 4 DIA. OFF. - 4 LEN. - 4 DIA. - .375 )
N1990 T4 M6
This is how I would like it to be:
N1940 Z-.3724 F50.
N1950 G0 Z.1
N1960 M5 M9
N1970 G91 G28 Z0.
N1980 M01
N1990 T4 M6
The way it currently works is it shuts off the coolant when the spindle reaches Z0. and I would like the coolant cut before it begins retracting to Z0. Can this be done?
Bob
Can this be done
yes
find this
pretract #End of tool path, toolchange
sav_absinc = absinc
absinc = one
sav_coolant = coolant
coolant = zero
#cc_pos is reset in the toolchange here
cc_pos = zero
gcode = zero
pcan
pbld, n, sccomp, *sm05, psub_end_mny, e
pcan1, pbld, n, sgabsinc, sgcode, "G28", "Z0.", scoolant, strcantext, e
and move "scoolant" up to the line above it.
put it next to *sm05
this was cut from an old V9 mpmaster post
an X post will have variables ending with $ signs
so it will look a little different.
Some machines will alarm out with 2 M codes on the same line. Its been 6 yeras since I ran a
Haas. I think a Haas will accept 2 M codes on one line but I'm not sure.
If it won't you'll have to do something like this
pbld, n, scoolant, e
Okay, so the Haas will not accept multipls Mcodes in one line of code so I added the following:
pbld, n$, scoolant, e$
This adds the M9 after each M5 throughout the program except at the end. How would I go about altering the coolant at the end of the program when the machine goes to the home position?
Thanks for all the help.
Bob
it should all ready be fixed
the first line of
peof #End of file for non-zero tool
is
pretract
which calls up the entire retact
definition you jut edited
Here is my peof code:
peof$ #End of file for non-zero tool
#pretract
comment$
#Remove pound character to output first tool with staged tools
#if stagetool = one, pbld, n, *first_tool, e
n$, "M5", e$
n$, "G53 G90 G0 Z0. X-24. Y0. M9 (LOAD UNLOAD POSITION)", e$
n$, "M30", e$
mergesub$
clearsub$
mergeaux$
clearaux$
"%", e$
Is there a good reason why the pretract would be turned off?
Bob
Okay, I think I am getting the hang of this by trial and error :-) Here is my modified peof:
pretract
comment$
#n$, "M5", e$
n$, "G53 G90 G0 X-24. Y0. (LOAD UNLOAD POSITION)", e$
n$, "M30", e$
mergesub$
clearsub$
mergeaux$
clearaux$
"%", e$
