Rotary axis cut
KenNelson
I'm trying to generate a simple rotary cut on a cylinder and need help please. The part is
mounted on a full rotary table, rotating about the X axis on a VMC. Part diameter is 11.260",
and I simply need to cut a 2-1/2" square pocket with .281" corner radii, .03" deep, the floor
of which is concentric to the o.d. The geometry I'm using is customer supplied and is a
surface/wireframe model, so I would not use projected geometry. Z-zero is the center of the
part is. I have tried surface/finish/parallel/rotary axis (all three positioning types) with varying
degrees of success. I have also tried Multiaxis/Curve5ax/4axis output. ARRRRGGGGHHH!
I cannot make Mastercam output good code. This seems like it should be a straightforward
cut, and hopefully some of you are able to help.
Any help is appreciated.
Cadcam-
No, I have not tried unrolling it. If this is the correct method to use, great - though I feel I should be able to generate this cut without modifying the geometry. I am able to share the file; should I try to upload it to FTP or mail it to your address? I really appreciate your offer of help.
By the way, do you know if there have been any additions to Blackbird Airpark recently (anything new besides the two a/c and the D21)? I may be passing through the eighborhood in April on the way to Phoenix and would love to show my son the park.
Thanks again
hi ken,
As for the unroll of the file this does not mean change the file.
Please put on the FTP or mail up to you sir.
As for the park .I have not looked in a while I will look this week and let you know.
And I forgot I should take mine over there.
Hi Jay:
Thank you very much for the file - that's what I was looking for. I thought, however, that I would be able to program some sort of surface cut to achieve this. I'm a believer in using any method that works though. I'm about to order the 4 and 5 axis machining book from this site; is that a good resource for this type of situation?
Thanks again Jay
