DEBUG
HEAVY METAL
these are my settings what ever i change does not effect output
# DEBUG/PROGRAM SWITCHES, debugging and program switches
bug1 : 0 # 1 = Output post to screen, 2 = output leader to screen
bug2 : 0 # Add postline label to each line at column 'bug2'
bug3 : 0 # Append whatline no. to each NC line?
bug4 : 1 # Append NCI line no. to each NC line?
whatno : yes # Do not perform whatline branches?
strtool_v7 : 1 # Use Version 7 toolname? [0=Filename,1=Name,2=PathName] #Tool!
get_1004 : 1 # Find gcode 1004 with getnextop?
fastmode : yes # Post speed optimizing, Set to NO for debug info
getnextop : yes # Gets next move information
arcoutput : 0 # 0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype : 1 # Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
breakarcs : yes # Break arcs into quadrants?
stagetool : 1 # 0 = Do not pre-stage tools, 1 = Stage tools
use_gear : no # Set to yes to output gear range codes
tplnout : no # Output plane code at sof, and tlchg (G17,G18,& G19)
# Note: Tooltable must be set to 'yes'
add_rad : 1 # 0 = No, 1 = add radius to Z in Axis Subs, -1 Subtract Rad
# Only valid for Axis Substitution
force_wcs : yes #Force WCS output at every toolchange?
toolchng : 1 #On a toolchange flag
What do you mean by "debug info"? Are you getting things like psof, pheader, etc. after the code on the same line? Which version are you using? If v9 are you talking about the .err file? Post a copy of a few lines of the output you're talking about and maybe that'll help us help you.
