post G17 G18 G19
kkominiarek
I am machining a complex layup mold. I'm using a Cincinnati Sabre vert mill machine with an Acramatic 2100 control. There are G17 G18 G19 moves all over this program. In the past I never had any posting problems. Now I'm getting axis errors after tool changes.
Right now my post does not put a G17 at tool changes. If the program is in G18 before a tool change it will still be in a G18 mode after the tool change.( unless a G17 or G19 is needed then the program updates to the correct mode)
Do I need to put a G17 at all tool changes in the post?
If the answer is yes.... and I'm in a G19 mode before a tool change and after the tool change the next tool also needs to be in G19 will the program update itself or will the G17 cancel the G19?
Hi,
I had the same when start to work with A2100 control with 3D machining.
I simple put sgplane as mentioned Russell to
pzrapid # Linear movement in Z axis only - at rapid feedrate
n, sgcode, sgplane, z
because I use
nobrk: no
at any movement between points for tool change will switch plane from G18 or G19 to G17
