Tombstone programming
connormac
OK with all your help I was able to get the 1st program written.(I think) Now I have a few questions.
1st our machine has 2 pallets. We are using ClusterTowers (4" bilocks) on each pallet.
We are doing 2 parts per face ( same op to each part). The program will do something on every vise. It will be a progression. every time pallet is complete you pull off 2 complete and move rest of parts to next station.
Offsets is where I start getting lost. B0 P1 and P2 to face the part. Do I then go to B270 P3 and P4 to face parts to thickness.
I guess what I am asking 1st is there a method to the madness of deciding work offsets.
When I rotate part 90 deg. to drill side hole in part that was B0 P1 what would you name offset B270 P11 ??
yes you would be well off to set up some type of convention to use. down the road it will then be second nature.
we use p1-p10 for op one p11-p20 for op2 and so on but u must decide the system you like along with those that work with it.
doug
I use one offset per part (1 thru 8 on a clustertower). When I'm machining the sides or any other angle for that matter I run a subprogram that will recalculate the offset for that angle and store the calcs to G59. This saves a lot of setup time and greatly lowers operator mistakes.
One operation for me includes everything that can be done in one clamping.
I agree with tim 1 hold is 1st op
As far as numbering work offsets it really depends on the tolerances you are working with and how accurately you model your tombstones, with vices and or fixtures on them usually the first op should not require you to pick up zeros!
I program everything from center of rotation but still give offsets to each part.
example you said you are doing two parts per face
so I use offsets as follows
P1 is the face of the top part B0
P2 is the right of the top part B90
P3 os the left of top part B270
then the bottom part is
P4 face B0
P5 right B90
P6 left B270.
now the offsets dont really tell you wich face of the tomb they are on I use the setup doc for that BUT to translate or rotate toolpath it makes it easier to keep the offsets in an equal spacinng.
just my 2 cents.
Rick,
I'm trying something like U said but,
face part 1 B0 P1
face part 2 B0 P2
left side part 1 B90 P3
left side part 2 B90 P4
right side part 1 B270 P5
right side part 2 B270 P6
This way the operator doesn't have to jump around the offset page. I don't know.
Then for next side just add 10 to the offsets. Like Doug said.
This is just a test of the emergency offset system.
Any advise will be noted and tried.
Thanks for all the help
yeah if you look in your transform or rotate toolpath you will notice it asks for offset increments
the bummer is you cant increment your first step then your next between the parts
there is only one choice.
so If I am making multiple parts it is easier to program 1 then transform down in the Y then Rotate about the center of rotation to get them to the next face.
Also on the transform ops you have to consider if you can group toolpaths to transform or do them individualy. like if you are spot drilling on the B0 face with out rotating you can spot the left side of the part on the B90 face and the right side of the part on B270.
you have to be carefull with that though the standard posts do not retract before moving to the next part from the face part. Tim who replied in here earlier fixed my post to retract properly for me.
