evolution serializing
rich
has anyone had to do this type of part number engraving? and if so what would be the best way to number engrave 1000's of parts on the machine without making 1000's of programs. something that the operator can do would be best. confused.gif maybe some type of macro?
I do believe the only way to do it is in the machine control using macro or parametric programming. I know Fadal has this feature built in for serializing part numbers.
It would be nice if there was a c-hook or macro you could run in Mcam.. anybody seen anything???
I wrote a Custom Macro eons ago that did this. Unfortunately I can't seem to find it. It did take a number hours to write though.
That's your best option, get someone to write a Macro for you.
JM2C
We are actually looking into this situation for one of our customers. They have a serial number that has to be projected onto a surface and then create the NC code. This cannot be done in macro programming on the control.
Anybody have a solution for this off the shelf???
Luc
The surface projection condition for sure makes this best suited to a C-Hook type application, without the possibility to have an operator or the control increment or auto-increment the serial number.
As for the 2D situation, I've done the same thing as James.
I accomplished this by creating numbers in Mastercam - 1" in height so that scaling could be used on the control. Posted the code in incremental mode, made them each a subprogram. Hand edited the code to use Z as a variable, etc, etc. Then created a main program to move a given position, call the 1st sub for the first number, move to the next position, etc.
The amount of flexibility in the program depends on whether your control supports scaling, macros, etc. So it starts as something fairly generic, but must be tightened up for specific conditions as the control losses functionality. For instance on a limited control, your subs must be written for a specific letter size rather than scaled in the program. If variables are not supported, you must write in your Z depth in the subs as well.
Couldn't figure out how to auto-increment the serial number on the control, or how to parse out digits in a serial number to convert them into separate sub calls for each digit. As a result in this program, the operator must edit the individual digit variables in order to represent the proper serial number. If someone has solutions to these issues, please post them here. I'd also have to wonder if the cut depth is not also scaled by the P factor. If someone could please ship me their machine with a Fanuc control for more advanced testing, that would be great - thanks in advance.
-Variables #101 to #105 represent a 5 digit serial number
-#107 - cut depth
-#108 - plunge feed
-#109 - cut feed
-P value on G51 line - letter height
-R value on G68 line - rotation angle
O0001 (SERIALNO)
(SERIAL NUMBER ENGRAVING)
G00 G17 G20 G40 G49 G80 G90
(EDIT SERIAL NUMBER)
#101=1
#102=2
#103=3
#104=4
#105=5
(LETTER HEIGHT)
#107=-0.01 (DEPTH)
#108= 5.0 (PLUNGE FEED)
#109=10.0 (XY FEED)
T1 M06 (ENGRAVING TOOL)
G51 I0. J0. K0. P0.10 (P - LETTER HEIGHT)
G68 X0. Y0. R0. (R - ROTATION ANGLE)
G00 G90 G54 X0. Y0.
G43 H1 Z1.
S5000 M3
(FIRST NUMBER)
G00 G90 X0. Y0.
G65 P[#101+1000]
(SECOND NUMBER)
G00 G90 X.6 Y0.
G65 P[#102+1000]
(THIRD NUMBER)
G00 G90 X1.2 Y0.
G65 P[#103+1000]
(FORTH NUMBER)
G00 G90 X1.8 Y0.
G65 P[#104+1000]
(FIFTH NUMBER)
G00 G90 X2.4 Y0.
G65 P[#105+1000]
G69 (CANCEL ROTATION)
G50 (CANCEL SCALING)
M05
G91 G28 Z0.
G28 X0. Y0.
G90
O1000
(#0)
G91
G00 X.251 Y0.
G90 Z.1
G01 Z#107 F#108
G91 X-.0451 Y.0096 F#109
X-.0412 Y.0192
X-.0392 Y.0385
X-.0353 Y.0481
X-.0314 Y.0625
X-.0255 Y.0721
X-.0176 Y.0769
G02 X-.0157 Y.1731 I.9529 J.1736
X.0157 Y.1731 I.9686 J-.0005
G01 X.0176 Y.0769
X.0255 Y.0721
X.0314 Y.0625
X.0353 Y.0481
X.0392 Y.0385
X.0412 Y.0192
X.0451 Y.0096
X.0431 Y-.0096
X.0412 Y-.0192
X.0392 Y-.0385
X.0353 Y-.0481
X.0314 Y-.0625
X.0255 Y-.0721
X.0176 Y-.0769
G02 X.0157 Y-.1731 I-.9529 J-.1736
X-.0157 Y-.1731 I-.9686 J.0005
G01 X-.0176 Y-.0769
X-.0255 Y-.0721
X-.0314 Y-.0625
X-.0353 Y-.0481
X-.0392 Y-.0385
X-.0412 Y-.0192
X-.0431 Y-.0096
G00 G90 Z.25
M99
O1001
(#1)
G91
G00 X.1431 Y1.
G90 Z.1
G01 Z#107 F#108
G91 X.1177 F#109
Y-1.
G00 G90 Z.25
M99
O1002
(#2)
G91
G00 X0. Y.8077
G90 Z.1
G01 Z#107 F#108
G91 X.0039 Y.0336 F#109
G02 X.0294 Y.0625 I.3402 J-.1219
X.0922 Y.0722 I.1871 J-.1442
G01 X.0392 Y.0144
G02 X.0863 Y.0096 I.5226 J-4.2968
X.0843 Y-.0096 I-.8755 J-8.0515
X.1059 Y-.0577 I-.0705 J-.2554
G01 X.0255 Y-.0289
G02 X.0294 Y-.0625 I-.3108 J-.1844
G01 X.0039 Y-.0336
X-.0039 Y-.0385
G02 X-.0294 Y-.0625 I-.3402 J.1219
G01 X-.4667 Y-.7067
X.5
G00 G90 Z.25
M99
O1003
(#3)
G91
G00 X.0275 Y.8077
G90 Z.1
G01 Z#107 F#108
G02 X.0255 Y.0625 I.2995 J-.0857
X.1176 Y.0866 I.1826 J-.125
X.0765 Y.0096 I.7951 J-6.0147
G01 X.0745 Y-.0096
G02 X.1176 Y-.0866 I-.065 J-.2116
X.0255 Y-.0625 I-.274 J-.1482
G01 X.0039 Y-.0336
X-.0039 Y-.0385
G02 X-.0255 Y-.0625 I-.2995 J.0857
X-.1176 Y-.0865 I-.1826 J.125
G01 X-.0745 Y-.0096
X.0431 Y-.0048
X.0412 Y-.0145
G02 X.0745 Y-.0528 I-.157 J-.3001
X.0569 Y-.0818 I-.2386 J-.2266
X.0294 Y-.0961 I-.4135 J-.1791
G01 X.0039 Y-.0529
X-.0039 Y-.0577
G02 X-.0294 Y-.0962 I-.4429 J.0829
X-.0569 Y-.0817 I-.2955 J.1449
X-.0745 Y-.0529 I-.2315 J.2472
G01 X-.0412 Y-.0144
X-.0431 Y-.0048
X-.0451 Y.0048
X-.0412 Y.0144
G02 X-.0745 Y.0529 I.157 J.3001
X-.0569 Y.0817 I.2386 J.2266
X-.0294 Y.0962 I.4135 J.1791
G01 X-.0039 Y.0577
G00 G90 Z.25
M99
O1004
(#4)
G91
G00 X.5 Y.3317
G90 Z.1
G01 Z#107 F#108
G91 X-.5 F#109
X.4176 Y.6683
Y-1.
G00 G90 Z.25
M99
O1005
(#5)
G91
G00 X.5 Y1.
G90 Z.1
G01 Z#107 F#108
G91 X-.4608 F#109
Y-.5337
X.0196 Y.0337
X.0314 Y.0385
G02 X.0745 Y.0528 I.2315 J-.2472
G01 X.0412 Y.0145
X.0451 Y.0048
X.0431 Y-.0048
X.0412 Y-.0145
G01 X.0039 Y-.0529
X-.0039 Y-.0577
G01 X-.0412 Y-.0144
X-.0431 Y-.0048
X-.0451 Y.0048
X-.0412 Y.0144
G00 G90 Z.25
M99
O1006
(#6)
G91
G00 X.5 Y1.
G90 Z.1
G01 Z#107 F#108
G91 X-.4412 Y-.5913 F#109
X-.0255 Y-.0337
G03 X-.0294 Y-.0817 I.2312 J-.1294
Y-.0866 I.2367 J-.0433
X.0294 Y-.0817 I.2606 J.0476
X.0569 Y-.0673 I.3569 J.2439
X.0745 Y-.0433 I.1886 J.239
X.0863 Y-.0144 I.1014 J.3412
X.0843 Y.0144 I-.0185 J.3616
X.0745 Y.0433 I-.1141 J.2822
X.0569 Y.0673 I-.3001 J.3112
X.0294 Y.0817 I-.2312 J.1294
Y.0866 I-.2367 J.0433
X-.0294 Y.0817 I-.2606 J-.0476
X-.0569 Y.0673 I-.3569 J-.2439
X-.0745 Y.0433 I-.1886 J-.239
X-.0843 Y.0144 I-.1028 J-.3471
X-.0863 Y-.0144 I.0151 J-.3556
X-.0745 Y-.0433 I.1141 J-.2822
G01 X-.0314 Y-.0336
G00 G90 Z.25
M99
O1007
(#7)
G91
G00 X0. Y1.
G90 Z.1
G01 Z#107 F#108
G91 X.5 F#109
X-.5 Y-1.
G00 G90 Z.25
M99
O1008
(#8)
G91
G00 X.2706 Y.6106
G90 Z.1
G01 Z#107 F#8
G91 X.0176 Y.0048 F#9
X.0373 Y.0048
G03 X.1176 Y.0865 I-.065 J.2116
X.0255 Y.0625 I-.274 J.1482
G01 X.0039 Y.0385
G03 X-.0137 Y.0625 I-.1523 J-.0007
G01 X-.0157 Y.0336
G03 X-.1176 Y.0866 I-.1826 J-.125
G01 X-.0745 Y.0096
G03 X-.0765 Y-.0096 I.7187 J-6.0243
X-.1176 Y-.0866 I.065 J-.2116
X-.0255 Y-.0625 I.274 J-.1482
G01 X-.0039 Y-.0336
X.0039 Y-.0385
G03 X.0255 Y-.0625 I.2995 J.0857
X.1176 Y-.0865 I.1826 J.125
G02 X.0569 Y-.0096 I-.0143 J-.2573
G01 X.0392
G02 X.0647 Y-.0193 I-.0382 J-.2472
G01 X.0039 Y-.0529
X-.0039 Y-.0577
G01 X-.0412 Y-.0144
X-.0431 Y-.0048
X-.0451 Y.0048
X-.0412 Y.0144
G01 X-.0039 Y.0577
X.0039 Y.0529
G02 X.0294 Y.0961 I.4429 J-.0829
X.0569 Y.0818 I.2955 J-.1449
G01 X.0412 Y.0145
X.0255 Y.0048
G00 G90 Z.25
M99
O1009
(#9)
G91
G00 X.4412 Y.5913
G90 Z.1
G01 Z#107 F#108
G91 X-.0314 Y-.0336 F#109
G02 X-.0745 Y-.0433 I-.1886 J.239
X-.0843 Y-.0144 I-.1028 J.3471
X-.0863 Y.0144 I.0151 J.3556
X-.0745 Y.0433 I.1141 J.2822
X-.0569 Y.0673 I.3001 J.3112
X-.0294 Y.0817 I.2312 J.1294
Y.0866 I.2367 J.0433
X.0294 Y.0817 I.2606 J-.0476
X.0569 Y.0673 I.3569 J-.2439
X.0745 Y.0433 I.1886 J-.239
X.0863 Y.0144 I.1014 J-.3412
X.0843 Y-.0144 I-.0185 J-.3616
X.0745 Y-.0433 I-.1141 J-.2822
X.0569 Y-.0673 I-.3001 J-.3112
X.0294 Y-.0817 I-.2312 J-.1294
Y-.0866 I-.2367 J-.0433
X-.0294 Y-.0817 I-.2606 J.0476
G01 X-.4667 Y-.625
G00 G90 Z.25
M99
[ 04-15-2002, 11:34 AM: Message edited by: Dave Thomson ]
Well I too had this problem, my boss even contacted our reseller for a possible solution.
Our problem was, how do I program the numbers to have the operator has as little input into the job as possible. I did all my lettering in 2D with box letters to get exact spacing. Fired up Easy Macro (macro program off the internet), programmed a part to use the calculator to sequence the numbers and post the toolpath. I can program about 500 numbers in 3 hours.
Easy Macro was my life saver
