Mpmaster post question
gms1
I recently added the code for turning coolant off with last Z move from the Mpmaster post. Now I cant figure out how to get it to NOT output the coolant off command on a null toolchange. How can I get it to not output the m8/m9 at null tool changes?
Running V8.1.1
Modified Mpfan post
Greg
Turning off the coolant early is actually quite complex. Check out the line that accomplishes this:
if cool_zmove = yes & (nextop=1003 | (nextop=1011 & t<>abs(nexttool))), coolant = zero
Let me translate:
if the switch to enable feature is on
and
the next operation is the end of file
or
the next operation is a tool change or null tool change and the current tool is not equal to the next tool based on a buffer file that I've written out (making it a true tool change rather than a null tool change)
then turn the coolant string selector variable off
The problem is that gcode 1011 is used for both a full tool change and a null tool change. You may be missing the create of the buffer list of tools (including null tool changes) that is queried to assign the value to the user-defined 'nexttool' variable.
All that for an M09 one line earlier...
Thanks for the reply Dave, the defintion to that line is what I really wanted! (I was banging my head trying to figure out what the heck 1011 meant smile.gif )
Gonna try this out today, im pretty sure I did remove a buffer... buffer5 to be exact, cause I didnt think I needed it. I thought it was for metacut/predator stuff. Back to work, i'll check in later.
Greg
Geez....
Well I found something I was missing
toolcountn = toolcount + 1 # Index!
toolcountp = toolcount - 1 # Index!
Lol! can't believe I didnt see that. Now its almost fixed, just seems like something I have defined is different from yours. Now, the coolant will turn on at pzrapidout, for no reason. like this...
G1G40Y3.3758 plin plinout
G0Z.1M8 pzrapid prapidout
X-2.6324Y2.7319 ptlchg0 prapidout
G1Z-1.F100. plin plinout
I know its something simple, I will find it!! At least now it doesnt turn on and off at null tool changes. Thanks a bunch Dave!
