Sequence No's for lathe G71 G70. How to change?
bigjohn
G'day all.
Is there a way to change the output of line No's in can cycles G71, G70 starting from 100 with increments of 2? At the moment I have:
G71 U2. R.2 U.4 W.2 F50.
N2 X64.703 S100
G1 X77.531 Z-5.234 F.1
G3 X78. Z-5.8 I-.566 K-.566
G1 Z-38.729
G2 X80.46 Z-41.699 I4.2
G1 X110.675 Z-56.806
G3 X114.072 Z-60.907 I-4.102 K-4.101
G1 Z-67.551
G2 X122.472 Z-71.751 I4.2
N4 G1 G40 X131.775
G0 Z1.18
M9
G0 X200.0 Z120.0 T0200
M01
N3 G0 T0303
G41 G0 X64.703 Z1.18 M8
G50 S6000
G96 S100
G70 P2 Q4
I'd like to have something like:
N100 X64.703 S100
G1 Z-38.729
G1 Z-67.551
N104 G1 G40 X131.775
G0 Z1.18
M9
M01
N3 G0 T0303
G50 S6000
G96 S100
G70 P100 Q104
Or something similar. Can someone help me get it right? I have tried many different ways but obviously the wrong ways, there is no change. I don't know what I'm doing any more. N2 in this example is the same as tool change line N2 for tool 2.
Thank you for any help.
John
Out of MPLFAN did you look here???
prcc_call_end$   #Rough canned cycle end
# Restore cc_1013 to the value it held prior to the rough # 1/17/03
# groove canned cycle. cc_1013 was changed in ptoolend. # 1/17/03
if tool_op$ = 208 | tool_op$ = 62, cc_1013$ = sav_cc_1013 # 1/17/03
if tool_op$ <> 208,
omitseq$ = sav_omitsq
#Close the ext file
result = fclose (sbufname3$)
#Open the ext file as a buffer
#Use the size to determine the start and end sequence
subout$ = sav_subout
size3 = rbuf(three, zero)
if omitseq$ = one,
ng70s = n$
ng70e = n$ + seqinc$
else,
if old_new_sw = zero, ng70s = n$ + seqinc$
else, ng70s = n$ + (seqinc$ * two)
ng70e = ng70s + (seqinc$ * (size3 - one))
pwrite_g70
Thank you Ron for your answer. I did find that section in the post, and it is the same as your code, however I don't know how to edit it to output seq No's starting from 100 with increments of 2.
Forgive my ignorance and thank you for your help.
John
Lathe X2-MR2 using the MPLFAN.PST
In the Control Definition on the NC Output page...
In the Sequence numbers groupbox ->
Output sequence numbers is unchecked
Start sequence number = 100
Increment sequence number = 2
and
In the MPLFAN.PST ->
omitseq$ : -1 #CD_VAR Omit sequence numbers? (use -1 to enable sequence for LCC)
Gives me this output ->
O0000
(PROGRAM NAME - T)
(DATE=DD-MM-YY - 30-01-08 TIME=HH:MM - 09:21)
(MCX FILE - T)
(NC FILE - C:MCAMX2-MR2LATHENCT.NC)
(MATERIAL - STEEL INCH - 1030 - 200 BHN)
G20
(TOOL - 1 OFFSET - 1)
(OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432)
G0 T0101
G18
G97 S347 M03
G0 G54 X2.1995 Z-.3739
G50 S3600
G96 S200
G71 U.1 R0.
G71 P100 Q102 U.02 W.01 F.01
N100 G0 X.6684 S200
G1 Z-1.3304
X1.0946 Z-1.7681
N102 X2.1995
G0 Z-.3739
G28 U0. V0. W0. M05
T0100
M30
Thanks Roger and Ron. You are very kind and helpful.
I am modifying a Generic Fanuc 2X Lathe.PST for a MORI LATHE - FANUC 15T CONTROL. I must have disabled something somewhere in the post that doesn't let me get those No's right. I tried Roger's rip with an unmodefied Mplfan.PST and a Fanuc 2X Lathe.PST that have not been edited and they worked very well. Now, my next job is to find where I messed up. Find the error or start from scratch.
Thanks again. The tip worked whith those 2 posts.
John
  • 1 year later...
I also need some help, When I post I get the sequence numbers but for every G70 Cycle the output is the sequenece numbers from the first Rough pass; for evey single finish.
(Flip Stock)
(TOOL - 1 OFFSET - 2)
( FC RGH2 )
G28 U0. W0.
G50 X10. Z10.
G0 T0102
G50 S700
G96 S400 M03
G0 X12.3 Z.185 M8
G41 X12.2 Z.135
G72 W.05 R.015
G72 P3 Q4 U.02 W.01 F.025
N3 G0 G41 Z0. S400
G1 X-.07 F.01
N4 G40 Z.135
G0 X12.2
M9
G28 U0. W0. M05
T0100
M01
(TOOL - 11 OFFSET - 12)
(OD FINISH RIGHT - 35 DEG. INSERT - VNMG-431)
( FC FNS2 )
G28 U0. W0.
G50 X10. Z10.
G0 T1112
G50 S1500
G96 S400 M03
G41 G0 X12.2 Z0. M8
G70 P1 Q2 --- this is from the first op
M9
G28 U0. W0. M05
T1100
M01
(TOOL - 5 OFFSET - 5)
(ID ROUGH MIN. .375 DIA. - 75 DEG. INSERT - NONE)
( ID RGH )
G28 U0. W0.
G50 X10. Z10.
G0 T0505
G50 S700
G96 S400 M03
G0 X.303 Z.15 M8
G42 X.403 Z.1
G72 W.035 R.015
G72 P5 Q6 U-.02 W.01 F.02
N5 G0 G42 Z-.188 S400
G1 X8. F.008
N6 G40 Z.1
G0 X.403
M9
G28 U0. W0. M05
T0500
M01
(TOOL - 7 OFFSET - 7)
(ID FINISH MIN. .5 DIA. - 55 DEG. INSERT - NONE)
( ID FNS )
G28 U0. W0.
G50 X10. Z10.
G0 T0707
G50 S1500
G96 S400 M03
G42 G0 X.403 Z.03 M8
G70 P1 Q2 --- this if from the fisrt op
M9
G28 U0. W0. M05
T0700
M30
