Varaibles for Lathe Stock Transfer.
crazy^millman
Here is a picture of it: STOCK_TRANSFER.jpg
Here is what CNC thinks is worthy of pulling out of it from MPLFAN:
pstck_trans$     #NCI code = 900 available variables:
#stck_spindle, stck_init_z, stck_final_z,
#stck_chuk_st_z, stck_chuk_st_x,
#stck_chuk_end_z, stck_chuk_end_x,
#stck_chuk_st_dz, stck_chuk_st_dx,
#stck_chuk_end_dz, stck_chuk_end_dx
if toolchng <> two, ptoolend$
toolend_flg = zero #Do not execute ptoolend again after xfer
!spaces$
spaces$ = zero
pbld, n$, "M00",e$
if prv_spaces$ > 0, " ",e$
if stck_spindle$ = 0, "(Xfer Part from Left Spindle)", e$
if stck_spindle$ = 1, "(Xfer Part from Right Spindle)", e$
spaces$ = prv_spaces$
Are any of the above code working? If so which ones and how do we activate them?
I am trying to adjust my Integrex Post so that once I have the number my posted code comes out right every time since all of the mi and mr are used up I can not go that method. I also see custom Parameters here. Are these the same that drilling ops used? If so can I use them the same way or do I need to do something different?
Ron
 OPS: PRM_LSTOCK_XFER
13205 Active spindle for stock transfer
13206 Z coordinate on stock to be transferred
13207 Previous Z coordinate on stock to be transferred
13208 Use stock BACK face as init Z position (True/False)
13209 Z coordinate on transferred stock
13210 Source chuck reference position before transfer
13211 Source chuck reference position before transfer
13212 Source chuck reference position after transfer
13213 Source chuck reference position after transfer
13214 Destination chuck reference position before transfer
13215 Destination chuck reference position before transfer
13216 Destination chuck pickoff position
13217 Destination chuck pickoff position
13218 Get final (Lathe) X coordinate from stock (True/False)
13219 Move Cplane origin to new stock position (True/False)
13220 Move Tplane origin to new stock position (True/False)
13221 Transfer geometry also (True/False)
13222 Level to store transferred geometry on
13223 Offset from source geometry level for transferred
geometry
13224 Use geolevel (as opposed entity level) (True/False)
13225 Blank original geometry (True/False)
13226 Entity with list of transferred entity IDs
13227 Entity with list of original entity IDs
OPS: OP_MISC Custom real / integer parameters
PARAMETER REFERENCE / Operation Parameters (10000s) • 277
OPS: PRM_LSTOCK_FLIP
13205 Active spindle for stock to flip
13206 Z coordinate on stock before flip
13209 Z coordinate on stock after flip
13210 Chuck reference position before flip
13211 Chuck reference position before flip
13212 Chuck reference position after flip
13213 Chuck reference position after flip
13221 Transfer geometry also during flip (True/False)
geometry
13224 Use geolevel [param: 13222] (as opposed entity level)
13226 Entity with list of transferred geometry entity IDs
13227 Entity with list of original geometry entity IDs
278 • MASTERCAM X / Post Parameter Reference
OPS: PRM_LBARFEED
13205 Active spindle for stock to barfeed
13206 Z coordinate on stock before barfeed
13208 Get initial Z position from stock face (True/False)
13209 Z coordinate on stock after barfeed
13210 Chuck reference position before barfeed
13211 Chuck reference position before barfeed
13212 Chuck reference position after barfeed
13213 Chuck reference position after barfeed
13228 Use chuck positions (True/False)
13221 Transfer geometry also during barfeed (True/False)
13223 Offset from source geometry level for xfer’d geometry
13224 Use geolevel [param: 13222](as opposed entity level)
13226 Entity with list of transferred entity id's
13227 Entity with list of original entity id's
13229 Operation type: 0= bar feed, 1 = bar feed with tool as
stop, 2 = bar pull
13230 Stock clearance for bar pull
13231 Grip length for bar pull
13232 Use plunge feed rate for approaching stock (True/
False)
13233 Tool X position for stop, bar puller
PARAMETER REFERENCE / Operation Parameters (10000s) • 279
OPS: PRM_LCHUCK_CLAMP
13205 Active spindle for chuck
13229 Operation type: 0 = clamp, 1 = un-clamp, 2 = reposition
13210 Initial chuck reference position
13211 Initial chuck reference position
13212 Final chuck reference position
13213 Final chuck reference position
280 • MASTERCAM X / Post Parameter Reference
OPS: PRM_LTAILSTOCK
13234 Operation: true = engage, false = retract
13235 Initial tailstock reference position
13236 Final tailstock reference position
13237 Is initial / final position based on stock position (True/
False)
13238 Is initial position based on tailstock minimum point
(True/False)
PARAMETER REFERENCE / Operation Parameters (10000s) • 281
OPS: PRM_LSTEADYREST
13235 Initial steadyrest reference position (Z)
13236 Initial steadyrest reference position (Z)
282 • MASTERCAM X / Post Parameter Reference
