THREAD MILL QUESTION
CNC-ERIC
Hi, everyone,
firs time to mill a one start right hand M20x1.5 OD/ID threads, I searched the forum, there was no answer to my question, so post it here,hope you guys can help me.
Qeustion:
first I mill a boss 0.7815" in Dia.,and the set thread mill Dia. is 0.57"(from the supplier, also I checked it by cutting), I set the Major D 0.7815", pitch 0.059055, use "wear" bottom up,
why there is no cutting? I did not set wear to any value.
thanks very much.
Eric
Got a sample file? Just do the threadmill by itself and put it on the FTP and then someone can look and point out what you are doing wrong. If cutting and id should be .787 Major thread Diameter. If cutting and Od thread then you should have the Minor which would be .669, but did not look at the chart took 2 times the pitch from the Major.
thanks Cris and Ron,
I made a mistake when I set Minor dia. for OD thread. now it is fine.
Another question, do you think I need do multiple cut for M20x1.5 on Aluminum? I set cutting speed 400sfpm and feed rate 8.4 ipm (chip load .003"/tooth), is the setting OK?
thanks
Eric
