pocketing cast iron
produca2
Hey guys I am going to run some cast iron parts and will be doing some 2d pocketing about .5/625 deep on 6 inch diametr blanks. I personally have never machined cast iron before and wondered if any of you have any tips before I get started. I will probably be using a cobalt endmill but I am not to sure about that, should I use carbide? I only have cobalt in my larger size end mills so thats the reaon for my tool material choice. Any advice is much apreciated.
You can cut pretty easy through cast iron.
I would use carbide so you can use a higher SFM.
Don't be afraid to push your chipload a bit, it's pretty soft.(or a rougher endmill)
my .02c ,it's dirty stuff, clean your machines good, after the run.
o.k. another question, I am using X2 mill level 1 so I dont get all the cool toolpaths that surfaces or solids let you run, so... the part I am pocketing is 6 inch round 1 inch thick pocketed .5 deep with a 1.5 inch dia. boss in the middle. the only toolpath I could get to work was a high speed peel mill following a single circular entity, and just editing the length of the trochoids. Otherwise I cant seem to find a way to run a pocket toolpath without clearing out the boss and everything. can anyone recomend something other than the high speed peel mill, or is the best possible solutioun to my pocketing problem?
I see no problems using coolant when cutting cast iron. You can lose some tool life, but the work area (vises/fixtures etc...) will be clean. If you run it dry, you're going to waste a lot of time prepping the cycle.
Also, to avoid coolant tank contamination in applications like that I sometimes use landscape fabric as an extra filter wink.gif
Bottom line is not to worry much about tools in this material, as it is very easy to cut, but admittedly very messy.
Mastercam does not have good material libraries setup by default. The other problem with the material libraries, is that once you get all the values set up, there are % percentage modifiers for almost every aspect of an individual tool. So your SFM could be 1200 by default, but your tool could be set to only use 25% of that value if it is defined as a HSS tool, or 45% if carbide, or what ever.
Try this: After you have created the toolpath, open the toolpath parameters dialog box, and right-click on the tool you are using, then select "Feed Speed calculator".
This will show you the actual SFM and IPT and will also show you all the % modifiers that are in use. It will also show you the final calculated RPM and Feed Rate.
HTH,
Also...if cast iron is so easy to cut why are the speeds and feeds mastercam is calculating for me coming out so damn slow???
Easy to cut is a relative term i guess, we deal with mostly 4140, 4340, 316 ss,inconel, ect.
Carbide endmill of any kind should handle 200-300 SFM. HSS or colbalt 100-150 tops.
I always do this so I can get a little better feeds and speeds, but jarret is sayin gthat I should be able to run like 2 or 3 hundred ipm with carbide, I am using a 3/8 carbide endmill and my contour feed rate after the feed and speed calc is only 7.23424 with a spindle speed od 2444. I changed the percentage modifier to 100 % even and thats all I get, I dont understand. I am gonna try to calculate this by hand and see what I get. I have a 7500 rpm spindle so I should get some faster feed rates I believe.
