speed and feed for spade drill
I need to drill 1.4375 hole through some
tubing. the dom tubing is 2.500 O.D. x 1.500 I.D
Im going to use a 1 7/16" tin coated spade drill.
any tips on speed and feeds for this.
thanks
i havent tryed it yet.
im going to spot drill first.
than use the spade.
i was hoping it would be better and faster
than a HSS drill.
Thanks for the imfo above,
helped alot..
I'm not a big fan of milling a hole or rectangular opening without a full pocket routine since the slug can catch and bind between the endmill and side wall of the opening. This can get real ugly real fast. Not that you can't do it. I see people do it all the time. But my experience has been it's better to make chips than slugs. It's a safer but slower way to go.
JM2CW
Ken
Is there a particular reason why you're using a spade drill and not any one of a variety of insertable drills (Ceratip's Magic Drill, Ingersoll's Quad Bore drills, etc) that are available? Most don't require a spot and can drill straight into an angled surface.
Thad
im opean to other typs of drills.
i have to drill two holes in each pc.
than im boring them .0015 under 1.500"
so i can press two 1.5" shafts in to tubing.
I have 330 pcs to do. so im all ears to what u all have to say.
thanks
Sandvik's Corodrill 880 series are nice, as are Iscar's [can't remember the name] inserted drills. Iscar's are shorter, which I like, and use square inserts which gives you more bang for the buck.
Both are expensive, so sit down before you quote them
Inserted drills definitely do not need a flat surface, though I think I would drill from the convex side of the tube, index 180, repeat, instead of going thru-and-thru because the inserted drill will not like the corners being in the cut before the center is. There shouldn't be a slug with an inserted drill, though you can get a disk-like piece when drilling through solid. I think the convex shape inside the tube will probably prevent this from forming in your application.
+1 They outperform all others I have tried.
I was always told insert drills had
to have a flat serface to drill on.
not really, you just need to slow down the feedrate until you get full dia. , then punch it thru.
