Mpmaster tool change question
gms1
I wrote a post a few years ago based off mpmaster post and I had to get rid of the tool change at the beginning of the program in the psof$ section of the post so I could put it at the end of the file. To do that I had to copy ptlchg_com to the psof section and removed the call to ptlchg_com in order to remove it (Thanks J Paris!). I tried it today on a new post i'm making with the new version of mpmaster and this doesn't work probably due to all the changes and what have ya.
I didn't like doing it that way, and I would like to make this post more universal for our machines so i'm wondering if there is a more elegant way of handling this? Is it possible to add some variable to check [if psof$ then skip ptlchg_com] and output the tool comment only? If I comment out pltchg_com in the psof section, it skips all the startup code for the cycle startup all the way past the g43 line.
You can try this;
Add a variable,
psof_flg   : 0      #Flag to cancel first tool change
insert the variable;
psof$            #Start of file for non-zero tool number
psof_flg = 1 #<<<<<<<<<<<<
ptravel
edit tool change from;
      if stagetool >= zero,
if omitseq$ = 1 & tseqno > 0,
if tseqno = 2, n$ = t$
pbld, *n$, *t$, "M06", ptoolcomm, e$
else, pbld, n$, *t$, "M06", ptoolcomm, e$
to;
if psof_flg = 1, pbld, *n$, ptoolcomm, e$
else, pbld, *n$, *t$, "M06", ptoolcomm, e$
else,
if psof_flg = 1, pbld, n$, ptoolcomm, e$
psof_flg = c9k
