5 axis post question for MCAM9
mfranco
I am in the process of setting up a 5 axis post by using the MPGEN5x_FANUC.PST. I have everything working except for the program rotation.
Right now the post outputs as follows:
G65 P9096
T1 M6
M997 (TOOL MESUREMENT MACRO)
G65P9507 C270. B50. (SETS ROTATION PARAMETERS IN MACHINE)(C IS PRIMARY,B IS SECONDARY)
G65 P9503 (APPLIES COMP)
G68 X0 Y0 Z0 I0 J0 K1 R?(PROGRAM ROTATION R=C+90)
G68 X0 Y0 Z0 I1 J0 K0 R? (PROGRAM ROTATION R=B)
S400 M3
G90 G0 X-61.997 Y19.131
Z99.997
G81 G98 Z-15.R10.F45.
X-63.371 Y82.717
G80
M5
G69 (CANCELS COMP)
G91 G28 G0 Z0 (SENDS Z HOME)
M30
I have three issues
1. I would like to use G53 G0 Z0 to send Z home.
2. I would like to use #511=270. #512=50. instead of the G65 P9507 macro.
3. In the two program rotation lines I need the "*p_out, *s_out" values in for R. In the first program line - R=*p_out + 90 and the second should be R=*s_out.
In this post sample, the R should read R0. (270+0) and second line R should read R50.
This part of the post for these two lines is:
if stagetool <= one, pbld, n,"G68 X0 Y0 Z0 I0 J0 K1 R", e
if stagetool <= one, pbld, n,"G68 X0 Y0 Z0 I1 J0 K0 R", e
The first two issues are just preferences, but this last issue is necessary.
Any help would be greatly appreciated.
Mfranco
For my post, I just change the G28 to a G53
From this;
#Select reference return code
sg28
G28
#First reference point return
sg30 G30 #Second reference point return
sg28ref #Target string
fstrsel sg28 mi3 sg28ref
To this;
sg28
G53
I also removed "*sgabsinc" and added a "G49" from prefreturn;
From this;
pbld, n, *sgcode, *sg28, *sgabsinc, "Z0.", e
to this;
pbld, n, *sgcode, "G49", *sg28, "Z0.", e
As far as the rest, it's hard to tell what mods that you have made to your post for me to be much help.
Thanks, I am not sure why I didn't see that.
As far as the rest of the post, I really haven't changed to much(mainly rotation limits and comments).
The part of the post program that outputs the tool change and angle rotation is below.
if stagetool <= one, pbld, n,"G65 P9096", e
if stagetool <= one, pbld, n, *t, "M6", e
if stagetool <= one, pbld, n,"M997", e
if stagetool <= one, pbld, n,"G65P9507", *p_out, *s_out, e
if stagetool <= one, pbld, n,"G65 P9503", e
Thanks again. Any additional help with the G68 lines would be great.
Note: Where I have 270+0 in the original post above, it should read 270+90.
This should fix items 2 and 3 for you. There are probably easier ways to do this, but this seems to work. Let me know if this works out for you.
I'm assuming that you want #511 and #512 as outputs from the machine rotation position(?)
Add this to your fmt list
# macro output
fmt 11 m_511 # macro var 511
fmt 11 m_512 # macro var 512
fmt R 11 m_521 # macro var 521
fmt R 11 m_522 # macro var 522
Change this
else
To This;
else,
m_511 = p_out
m_512 = s_out
m_521 = m_511+90.
m_522 = m_512
if stagetool <= one, pbld, n, 35, "511=", *m_511, e
if stagetool <= one, pbld, n, 35, "512=", *m_512, e
if stagetool <= one, pbld, n,"G68 X0 Y0 Z0 I0 J0 K1", *m_521, e
if stagetool <= one, pbld, n,"G68 X0 Y0 Z0 I1 J0 K0", *m_522, e
[ 06-08-2008, 06:58 PM: Message edited by: mgsanchez ]
Better Still
else,
m_511 = p_out
m_512 = s_out
m_521 = m_511+90.
m_522 = m_512
pbld, n,"M997", e
I am running short on time right now so I just quickly inserted into post as mentioned above.It seems to have worked good except "R360. should read "0". I will looked into it a little bit more as soon as I can.
M997
# 511=270.
# 512=50.
G65 P9503
G68 X0 Y0 Z0 I0 J0 K1 R360.
G68 X0 Y0 Z0 I1 J0 K0 R50.
Thanks again. I will post back once everything is good.
I just wanted to say thanks to you guys for helping me with this post. Although I have not been able to test it out completely, it does seem to work correctly. Over the next several weeks, I will be testing the post out before I put it out on the floor. As far as the 360+ degree output, that is just the program rotation and not the head rotation. If you have time you can post a sample, but if not, don't worry about it. I have learned alot by working on this post and I will be continuing to analyze it for better understanding.
Once again, thanks.
