Posting G13's
Rob @ Target Machine
Axis ---I wish I had macro B.
This is a yasnac I80 control on a Matsuura mc510-vf. The G13's were an option for the control, but no macros that I am aware of. The control ignores any line beginning with #. I'm just trying to define a few cutom drill cycles to output the G13'3 so I don't have to make manual edits so often.
_______________________________________________
I hear that. The only two Yasnac controls I ever used were an MX2 Mill and LX1 lathe.
Great controls with lots of options for canned cycles.
It looks like your winning this battle and in time it will be done.
BTW: I am tobyaxis on CNC Zone, LOL.
Nice to see you here and welcome to the official MC Forum
Crazy^Millman :
It sounds like you are talking about making the post output as a main or sub depending on the switch value. That is not what I am looking for. This is how I am posting now:
G00 G90 G54 X0. Y0. S6000 M08
G91 G43 H1 Z0. M03
G92 Z.05 M08
G90
M98 P0101
O0101
G0 Z.01
G1 Z-.012 F1.
G13 I.0703 F3. D27.
G1 Z-.057 F1.
G13 I.0503 F3. D28.
G1 Z-.067 F1.
G13 I.0503 F3. D28.
G13 I.0508 F5. D28.
G13 I.0508 F5. D28.
G1 Z-.012 F20.
G13 I.0703 F5. D27.
G0 Z.05
M99
G90
X.75
M98 P0101
X.25 Y-.25
M98 P0101
X.5
M98 P0101
X.75 Y-.5
M98 P0101
X.25 Y-.75
M98 P0101
X.5
M98 P0101
G00 M09
as you can see, I have a complete sub right in the middle of my main. If I could get that section to post after the end of the main I'd be all set. Can I make this section of code come out at the mergesub section at end of post?
Well this is where I think you may need to look at how you are calling your sub calls and outputting it from that point. Really comes down to that. I would look at the format 1 Fadal post for V9 it did a good job of what you are after. If you do not have it call you dealer they should be able to get you a copy.
Millman :
Yeah that's alot to interpret though. I noticed that the Mpmaster post doesn't use buffers 1 or 2, and doesn't use pwritebuf1 or any other # to buffer the sub code, yet it still posts subs if you check the subs box or transform. I can see a little better how the Fadal post is handling the task although I'm still a bit lost. I have to thank you for getting me this far. I will figure this out eventually.
Axis :
Nice to see you here too. This forum is great for technical stuff like this MP language. I upgraded to X2mr2, but I still need 9.1sp1 for work, so I'll be learning X2 at home. Maybe in time I'll have more to offer on the X transition from 9 in the CNC Zone soon.
You can call me Toby, LOL.
Sounds like your going to be having Fun Learning!!!
I will have tons of that when my software and sim for X3 arrive from Cimquest.
This site is the best for MC on the net so absorb as much as you can from the Masters of Mastercam.
Success!!! almost
Ok so I defined my vars, assigned the drl_prm#'s,mi's, and mr's
for my G13 cycle.
# format statements for custom vars
fmt Z 2 depth_1
fmt Z 2 depth_2
fmt Z 2 depth_3
fmt Z 2 depth_4
fmt Z 2 depth_5
fmt I 12 rad_1
fmt I 12 rad_2
fmt I 12 rad_3
fmt I 12 rad_4
fmt I 12 rad_5
fmt F 15 plunge_fr
fmt F 15 rough_fr
fmt F 15 finish_fr
fmt F 15 rapid_fr
fmt D 4 comp_1
fmt D 4 comp_2
fmt D 4 comp_3
fmt D 4 comp_4
fmt D 4 comp_5
fmt Z 2 clear_hgt
fmt Z 2 feed_hgt
# custom drill cycle variables *******************************
# ---------------------- custom drill parameters
depth_1 = drl_prm1 # depths and radii are in drl_prm 1-8
rad_1 = drl_prm2
depth_2 = drl_prm3
rad_2 = drl_prm4
depth_3 = drl_prm5
rad_3 = drl_prm6
depth_4 = drl_prm7
rad_4 = drl_prm8
depth_5 = drl_prm9
rad_5 = drl_prm10
# ----------------------- misc reals
plunge_fr = mr1 # feedrates are in ---------- mr 1-4
rough_fr = mr2
finish_fr = mr3
rapid_fr = mr4
clear_hgt = mr9 # clearance and feed planes - mr9-10
feed_hgt = mr10
# ----------------------- misc integers
comp_1 = mi3 # cutter comps are in ------- mi 3-5
comp_2 = mi4
comp_3 = mi5
comp_4 = mi6
comp_5 = mi7
Then wrote the script for the custom cycle.
pdrlcst #Custom drill cycles 8 - 19 user option
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
if drillcyc = 8, # Subprogram Call
sub_prg_call = peck1
pbld, n, "M98", *sub_prg_call, e
if drillcyc = 9, # ----G13 ------- Standard Feedthru
psub_call_s
subout = 1 #<----------------------------------------------------------------------here
psub_st_s
pbld, n, "G0", *feed_hgt, e
pbld, n, "G1", *depth_1, *plunge_fr, e
pbld, n, "G13", *rad_1, *rough_fr, *comp_1, e # solder well depth
pbld, n, "G1", *depth_2, *plunge_fr, e
pbld, n, "G13", *rad_2, *rough_fr, *comp_2, e # roughing depth
pbld, n, "G1", *depth_3, *plunge_fr, e
pbld, n, "G13", *rad_2, *rough_fr, *comp_2, e # rough at finish depth
pbld, n, "G13", *rad_3, *finish_fr, *comp_2, e # finish feedthru diameter
pbld, n, "G13", *rad_3, *finish_fr, *comp_2, e # spring pass
pbld, n, "G1", *depth_1, *rapid_fr, e
pbld, n, "G13", *rad_1, *finish_fr, *comp_1, e # cut burr at solder well depth
pbld, n,"G0", *clear_hgt, e
psub_end_s
subout = 0 #<--------------------------------------------------------------------and here
pcom_movea
pdrlcst_2 #Custom drill cycles 8 - 19, additional points user option
pdrlcommonb
if drillcyc = 8,
pcan1, pbld, n, pxout, pyout, strcantext, e
if drillcyc = 9, # ----G13 ------- Standard Feedthru Additional Points-------------------
pbld, n, "M98", *sub_prg_no, e
pcom_movea
Notice where I used psubout = # buffer channel and voila I can force subs from the custom cycle.
O0100
G91 G80 G40 G17 G00 G98
G54
G90 X0 Y0
M01
T1 M06
G91 G43 H1 Z0. M03
G92 Z.05 M08
G90
M98 P0101
G90
X.75
M98 P0101
X.25 Y-.25
M98 P0101
X.5
M98 P0101
X.75 Y-.5
M98 P0101
X.25 Y-.75
M98 P0101
X.5
M98 P0101
G00 M09
G91 G28 Z0. M19
G28 Y0.
G53 X-15.
M00
M99
O0101
G0 Z.05
G1 Z-.012 F1.
G13 I.0703 F3. D27
G1 Z-.057 F1.
G13 I.0503 F3. D28
G1 Z-.067 F1.
G13 I.0503 F3. D28
G13 I.0508 F5. D28
G13 I.0508 F5. D28
G1 Z-.012 F20.
G13 I.0703 F5. D27
G0 Z1.
M99
Sorry this is so long, but I posted all changes so someone
else can use this as reference if interested.
Yes sir that is why I do it as well. I have a bunch of things where I did probing, Dual Turret Sync, and others things and others do the same around here. I like what I see and good job putting that together. That went into my notes so I appreciate your willingness to share your results. cheers.gifcheers.gif
Thought looking at it I may see a problem. You are using the drilcyc 9 in the 1st call of your sub method and then again in the 2nd call of the sub cycle. The 2nd drill cycle only come into play when you are using more than one point. I recommend you look at the mi or mr method to call your sub in a post block verse handing this in your 1nd point drill cycle call. May see less problems down the road.
