Outputting XYZ values without letter prefix?
m_morgan
I'm in the process of making a post for a router, and to set up the initial move, it uses a line:
QX=100.000 QY=50.000 QZ=2.000
In the post I'm using:
"QX=", xabs, "QY=", yabs, "QZ=", zabs
to output the code, but when I post, it produces:
QX=X100.000 QY=Y50.000 QZ=Z2.000
What parameter do I use to output only the VALUE of the co-ordinate, not the whole string. Obviously it's not #abs.
Thanks in advance!
Michael,
In you post processor,
Try changing this:
fmt X 2 xabs #X position output
fmt Z 2 zabs #Z position output
fmt X 3 xinc #X position output
fmt Y 3 yinc #Y position output
fmt Z 3 zinc #Z position output
To that:
fmt QX= 2 xabs #X position output
fmt QY= 2 yabs #Y position output
fmt QZ= 2 zabs #Z position output
fmt QX= 3 xinc #X position output
fmt QY= 3 yinc #Y position output
fmt QZ= 3 zinc #Z position output
I did not try it but seems to me that it should do the trick.
Martin,
Thanks for the response, but that changes all of the XYZ values to QX= QY= QZ=, whereas I just need the QX= QX= QZ= line once (for setting the 1st co-ordinate. The rest of the values are just XYZ.
I was thinking that there must be a way to strip the letter off?
You could then try creating 2 post blocks to format the moves and then call the different post blocks like so:
pfirst_move # call of post block for first move
pbld,n, ... # positionning from the mastercam post
pother_moves # call of post block for other moves
and add these 2 post blocks:
pfirst_move # format output for first move
pother_moves
Hope that help,
The fmt statements are global, you can only have one.
The way I would do a temporary change would be, in the post block where you are using the QX= ect, just before the output:
result = nwadrs(strqxeq, xabs)
result = nwadrs(strqyeq, xabs)
result = nwadrs(strqzeq, xabs)
n$, xabs, yabs, zabs, e$
When done outputting the value, in the same postblock, set the values back:
result = nwadrs(strx, xabs)
result = nwadrs(stry, xabs)
result = nwadrs(strz, xabs)
Near the top of the post there should be some string definitions, make sure to add the ones you want to use.
Table should look like this:
#String and string selector definitions for NC output
#Address string definitions
strc "C"
strf "F"
stri "I"
strj "J"
strk "K"
strm "M"
strn "N"
stro "O"
strp "P"
srad "R"
srminus "R-"
strx "X"
stry "Y"
strz "Z"
strl "L"
strqxeq "QX="
strqyeq "QY="
strqzeq "QZ="
sblank
Allan
Michael,
You need to create some variables to capture the xabs, yabs, and zabs values. Those variable are not assigned the X,Y, or Z pre-fix until they are actually output.
First, backup your post.
In the variable initialization section, add the following variables:
myvarXabs    : 0
myvarYabs : 0
myvarZabs : 0
This creates three new variables (make sure they start in the first column of the post).
Now in the format section below all the columns that contain the normal format assignments, add the following:
fmt  QX= 2 myvarXabs
fmt QY= 2 myvarYabs
fmt QZ= 2 myvarZabs
This sets the format assignment for your new variables to match the format statement for the original xabs, yabs, zabs variables, but has the prefix you desire...
Now somewhere above your output line you need to add the following code:
       myvarXabs = xabs
myvarYabs = yabs
myvarZabs = zabs
n$, myvarXabs, myvarYabs, myvarZabs, e$
This will give you a line with the output you want, with a sequence number in front. Just omit the "n$," parameter if you don't want a line number.
Hope that helps,
Allan's method is nice too. Less work to do in the post as long as you only need to output those values once. If you need to output the variables with the different formatting in more than one spot (ex. you need those values output from pheader$, psof$, ptlchng$, or elsewhere), then you would have to use the "nwadrs" assignment in multiple spots...
Glad you got a solution that worked.
Allan, thanks for showing me something new! I'll have to play around with the new address function...
Colin, I had a play with that too, and it works quite nicely. Went with the easy option though, as I only need to call the parameter once. Very good to know I can temporarily change values within a post block. Will definitely come in handy!
Was wondering why it wouldn't work, but then realised I was calling xabs, yabs, zabs. Stuck a * in front of each to output the value. Works find now! Why would that be?
Asterix is the "force" variable output modifer. The variables weren't being output due to "modality". The post thought they had already been output somewhere else. This is explained in the Mastercam Post Reference Guide for V9, which you should get a copy of. I think it was on the FTP for a while... It is like 29 mb, so I can't email it to you...
Normally you can get a copy through your reseller.
All...
I would consider Allan's solution to be "the best" as there are no possible "side effects".
Using the other proposed methods of assigning the values from xabs, yabs, zabs into other variables and then outputting those "new" variables does work, but...
You have bypassed outputting xabs, yabs, zabs as xabs, yabs, zabs - thus the prv_xabs, prv_yabs, prv_zabs (automatic previous) variables will not get updated.
This could possibly cause a modality issue on the next output the the "real" xabs, yabs, zabs variables, immediately after this "initial position" line.
