xform-translate problem
Elad
I experienced a a scary eek.gif bug :
When i xform-translate-all entities,and then i reg.path,the holes in the part stayed behind in the original position.
I had this bug more then once,but i can't find anything wrong that i'm doing.
Did anyone had this problem??
I'm in v9 sp1.
...the correct blessing has to be said
I'm sure that gets overlooked often.
I burn incense and light candles before I transorm entities that have toolpath attached to them. wink.gifwink.gifwink.gifwink.gifwink.gifwink.gif
elad,
All joking aside, Mcam software doesn't need blessings or candles or spells to run correctly. Someone reading the post may not understand the reason for all the "smilies". Could you download the file to the FTP? Is Mask turned "on" for any of the levels? If the geometry is on a level other than the one checked in the Mask column, that geometry will not be selected for an X-Form operation. One test of this is if you select All-Entities and the holes don't highlight like the rest of the entities on the screen. As long as the highlight color isn't the same as the geometry color, this will be easily seen. HTH smile.gifbiggrin.gifsmile.gif
