Heidenhain communication.
neil qwerty
Steve Hattori, we're running a TOS HMC. I did talk to them a few years ago when I was setting up the old computer but if I recall correctly, they didn't seem to be much help back then.
As for NX6, I've only been using it a couple of weeks now but I'm really starting to like it. We skipped NX5 so it took some getting used to, mostly with the way the dialogue boxes look. Some areas they've added more mouse clicks (ex: placing points in a sketch, you have to click apply after placing each one, ARGHH!!), other areas have been streamlined. Probably the most important new feature for us (which was added in 5.02) is the new and long overdue hole series. If this works as well as I hope it does, this will save us hours!
SOLVED!!! Thanks for your help with this guys. I needed to change some of the group policies on the computer, here's what worked:
Use the built-in XP Group Policy editor (gpedit.msc) and locate the Computer ConfigurationWindows SettingsSecurity SettingsLocal PoliciesSecurity Options branch. Make sure to disable the following policies:
"Domain Member: Digitally encrypt or sign secure channel data (always)"
"Domain Member: Digitally sign secure channel data (when possible)"
"Domain Member: Digitally encrypt secure channel data (when possible)"
and
use the built-in XP Group Policy editor (gpedit.msc) and locate the Computer ConfigurationAdministrative TemplatesSystemUser Profiles branch. This is described in Microsoft's Technet Q327462. Make sure to enable the following policy:
"Do not check for user ownership of Roaming Profile Folders"
Hope this helps someone out.
Neil.
