To 4 axis gurus ,please help !!!!
mig
Hi All,
I have been using Mastercam for a long time, but I never used for 4 /5 axis machining. I’m glad I have a chance to do it . I purchased the book “4/5 Axis Training tutorial “ by “In House Solution” and now I’m
about to finish tutorial 3 –“AXIS SUBSTITUTION ;ROLLDIE C-HOOK”.
File for tutorial is here : http://www.emastercam.com/files/x3_45axis.html
Tutorial 3 -Geometry and completed tool path
Everything looks fine but in verify mode after machining pocket part is rotating and next rolldie c- hook operation it simulate on wrong place . I thing problem with some setups or .. .MMD file .
I am using ” mill default . mmd “ ,everything recommended by tutorial
Can somebody explain what is my problem ?
Also I ask if anyone can share with me working .mmd file for regular VMC/ 4 axis (haas)so I can look thru set ups.
I spent almost half day to figure out the problem with no success. So I gave up and asking for help.
Thank you in advance
Yes, for some reason verify of that roll die example makes it look like it is cutting 90 degrees out of position, but its really not. I think this is just a limitation of verify. There is a setting in mach def, but it just moves all the tool paths 90 degrees from where it was. Ron is right, if you look at the output gcode closely you will see the c-axis angles are within the same range as the other tool paths.
Since this is an In-House Solutions example maybe someone from In-House could give us some better insight as to why this occurs with this example.
