Tombstone rotation problem
connormac
I have this part set where it is in the tombstone from the centerline of the tombstone. touched the tool off and offset is correct to centerline. I have 2 slots at a angle +33.53° and -33.53°. I rotated the tombstone 33.53 both directions. Just to check I rotated around X 90 degrees and the bottom of the slots I am milling are flat so know the rotation is correct. But for some reason it does not machine correctly. I checked the numbers they seem to be correct. banghead.gifbanghead.gif
It verifies correctly. Its Friday!! If you what to see the part it is in X3-files on ftp site. "Kitamura rotation problem". Thanks for all the help.
connormac
i turned off rotary axis button on the first op and created a new top view for center of rotation and reselected all the planes(for index) and it looks good here is some of the code i posted with my kitamura HX500i post if you want i can send you the file back or code i have
when i created the new top view i rotated it 90 deg about x axis so z axis is up so MC knows what to rotate about
hope this helps you out
N11G30X0.Y0.
N16M28 (CHIP CONVEYOR ON)
(3/32" 2 FLUTE CARBIDE EM TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .09375)
(MILL TOP)
N21T1M6
N26S12000M3
N31M11
N36G0G90G56B0.
N41M10
N46G0G17G90G56X.2406Y.3326
N51G43H1Z8.
N56Z5.03
N61G94G1Z4.9F10.
N1191G40X.0735Y.4189
N1196G0Z8.
N1201G91G30Z0.
(MILL SLOT ON B33.53° SIDE)
N1206S10000M3
N1211M11
N1216G0G90G57B33.53
N1221M10
N1226G43H1Z8.
N1231X-2.7518Y1.813
N1236Z4.2096
N1241G1Z4.0902F3.
N3516X-2.7421Y1.8179
N3521G40X-2.7468Y1.813
N3526G0Z8.
N3531G91G30Z0.
(MILL SLOT ON B-33.53° SIDE)
N3536S6000M3
N3541M11
N3546G0G90G58B326.47
N3551M10
N3556G43H1Z8.
N3561X2.7415
N3566Z4.2096
[ 04-17-2009, 01:59 PM: Message edited by: Tony35 ]
Thanks Tony. Your numbers look about the same as mine. I think when a previous op was done they got the angle holes off so no matter what, the pocket cannot be in the right place. thanks for looking.I will let you know what I find out. Looks like I might get to work this weekend on rework. I hate rework!
Tony in that didn't work.
sav_rot_on_x = 1 #SET TO 1 FORCE B OUTPUT WITH NO INDEX
is not in my post.
Jay, yes we go from top and rotate around y axis. I'll have to check about what the post is set for. Our resaler sent it to us.
I do know if you go at least 90° then back to zero it will put in the B0. but anything less than 90° you have to put in B0. For now I just set up a misc int to have it put in B0 when I need it. I'm a danger to myself.
