Plunge milling
Is there a tutorial or demo on plunge milling anywhere. I looked through the documentation files and didn't find anything, but I may have just overlooked it. I also searched the topic and tried some of the things discussed, with poor results. So I think I am missing something and just need to read a breakdown of what it is asking for.
Thanks in advance
I am trying to plunge mill a pocket in a forging. So i tell it what the drive and check surfaces are then select the grid. On the grid i select the left lower corner of the pocket and the right upper corner of the pocket. The toolpath that it gives does not appear to be correct.
Now my questions are is this possible, how describe the stock beside my stock setup, and am I selecting the grid correctly?
I would post it on the FTP but I am not allowed to do so.
Thanks again
I just searched the forum and experimented. I think I'm pretty good at it now. Some key points I use:
:follow NCI (pocket) as grid stinks
:you dont have to do the whole part in one op
as you may be more efficent attacking it in
multiple ops-directions
:Same as other surfacing, cut depths to absolute
and min & max set the same and to your max depth
(eliminates pecks and wasted motion)
:Follow tool mfg guidelines for stepover and such
I just put a file on the cadcam's ftp with surfaces the represent what i am doing. The blue surface is my finish for the pocket and the fusia surface is my forging. I am trying to use a 2" iscar plunge mill and rough net +.05
thanks
sorry the file is called plunge surfaces in the X3 files folder
I placed an example on my FTP, the link is above
PLUNGE SURFACES_JMP.MCX
Again I can't save a file to Jay's FTP.
I created a pocket toolpath and ghosted it out, I used the nci of that tool path to drive the Plunge routine.
I used the floor and bottom radius' as drive surfaces and the vertical walls as checks.
