Posting question
Greg_J
When I post a program that cuts arc's it gives me a XYZIJ in every line is there a way to take out redundant info. I don't need the Z in a line that's not moving in the Z or a I0, J0 either.
I need to shrink the size of my program.
Thanks for the help.
Greg
Can you put up this part of the post:
plinout         #Output to NC of linear movement - feed
pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e$
pcirout #Output to NC of circular interpolation
if not(arccomp), pcompwarn
if fmtrnd(xabs) = prv_xabs & fmtrnd(yabs) = prv_yabs & fmtrnd(zabs) = prv_zabs, result = force(xabs,zabs) #force coordinate on full arc
if hel_2100 = one, pcirout2
else, pcirout1
pcirout1 #Output to NC of circular interpolation
pcan1, pbld, n$, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e$
pcirout2 #Output to NC of circular interpolation
if (plane$ = zero & fmtrnd(zinc)<>0)
| (plane$ = one & fmtrnd(xinc)<>0)
| (plane$ = two & fmtrnd(yinc)<>0), phelout
else, pcirout1
phelout #Output to NC of helical interpolation
if plane$ = zero,
result = nwadrs(strk, lead)
lead = abs(zinc/sweep$*360)
if plane$ = one,
result = nwadrs(stri, lead)
lead = abs(xinc/sweep$*360)
if plane$ = two,
result = nwadrs(strj, lead)
lead = abs(yinc/sweep$*360)
pxout, pyout, pzout, *lead, pcout, parc, feed, strcantext, scoolant, e$
parc #Select the arc output
if (plane$ = zero & (arctype$ = one | arctype$ = four)) | #XY Plane
(plane$ = one & (arctypeyz$ = one | arctypeyz$ = four)) | #YZ Plane
(plane$ = two & (arctypexz$ = one | arctypexz$ = four)), #XZ Plane
result = newfs(two, iout)
result = newfs(two, jout)
result = newfs(two, kout)
else,
result = newfs(three, iout)
result = newfs(three, jout)
result = newfs(three, kout)
#if (plane$ = 0 & arctype$ < five) | (plane$ = 1 & arctypeyz$ < five) |
# (plane$ = 2 & arctypexz$ < five) | full_arc_flg$ | arc_pitch$,
(plane$ = 2 & arctypexz$ < five) | full_arc_flg$,
#Arc output for IJK
# If you do NOT want to force out the I,J,K values,
# remove the "*" asterisks on the *i, *j, *k 's below...
if plane$ = zero, *iout, *jout, kout #XY plane code - G17
if plane$ = one, iout, *jout, *kout #YZ plane code - G19
if plane$ = two, *iout, jout, *kout #XZ plane code - G18
!i$, !j$, !k$
else,
#Arc output for R
if abs(sweep$)<=180 | (plane$ = 0 & arctype$ = five) | (plane$ = 1 & arctypeyz$ = five) |
(plane$ = 2 & arctypexz$ = five), result = nwadrs(srad, arcrad$)
else, result = nwadrs(srminus, arcrad$)
*arcrad$
Then someone can help you get it straightened out.
I hope this is it, it's not the exact same as the one you posted.
else, pcirout1
pcan1, pbld, n$, `sgfeed, sgplane, *sgcode, sgabsinc, pccdia,
pfxout, pfyout, pfzout, pcout, parc, feed, strcantext, scoolant, e$
if (plane$ = zero & abs(zinc)>=0.0005)
| (plane$ = one & abs(xinc)>=0.0005)
| (plane$ = two & abs(yinc)>=0.0005), phelout
else, pcirout1
if plane$ = zero, result = nwadrs(strk, lead)
if plane$ = one, result = nwadrs(stri, lead)
if plane$ = two, result = nwadrs(strj, lead)
pcom_moveb #Common motion preparation routines, before
pxyzcout
ps_inc_calc
pncoutput #Movement output
pcom_moveb
comment$
if coolant$ <> 0 & coolant$ <> sav_coolant,
pbld, n$, sm09, e$
sav_coolant = coolant$
if coolant$ = 1, sm09 = sm09_0
if coolant$ = 2, sm09 = sm09_1
if coolant$ = 3, sm09 = sm09_2
if cool_zmove = yes$ & (nextop$=1003 | (nextop$=1011 & t$<>abs(nexttool))), coolant$ = zero
pcan
if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
if gcode$ = zero, prapidout
if gcode$ = one, plinout
if gcode$ > one & gcode$ < four, pcirout
if mr_rt_actv, #Restore absolute/incremental for G51/G68
absinc$ = sav_absinc
mr_rt_actv = zero
pcom_movea
pcom_movea #Common motion preparation routines, after
pcan2
pe_inc_calc
pdwl_spd$ #Call from NCI gcode 4
pspindle
comment$
pspindchng
pcan
if fmtrnd(dwell$), pcan1, pbld, n$, *sgcode, *dwell$, strcantext, e$
else, pcan1, pbld, n$, strcantext, e$
pcan2
prapid$ #Output to NC of linear movement - rapid
pncoutput
pzrapid$ #Output to NC of linear movement - rapid Z only
pncoutput
plin$ #Output to NC of linear movement - feed
pncoutput
pz$ #Output to NC of linear movement - feed Z only
pncoutput
pmx$ #Output to NC of vector NCI
pncoutput
pcir$ #Output to NC of circular interpolation
pncoutput
#Pre-process rotary motion control flags
pmx0$ #5 axis gcode setup
if drillcur$ = zero,
if fr$ = -2,gcode$ = zero
else, gcode$ = one
plin0$ #Linear movement, mill motion test
pmotion_su
pcir0$ #Circular interpolation, mill arc motion test
pmotion_su
# Motion output components
pbld #Canned text - block delete
if bld, '/'
pfbld #Force - block delete
pccdia #Cutter Compensation
#Force Dxx#
if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
sccomp
if cc_pos$, tloffno$
pfxout #Force X axis output
if absinc$ = zero, *xabs, !xinc
else, *xinc, !xabs
pxout #X output
if absinc$ = zero, xabs, !xinc
else, xinc, !xabs
pfyout #Force Y axis output
if absinc$ = zero, *yabs, !yinc
else, *yinc, !yabs
pyout #Y output
if absinc$ = zero, yabs, !yinc
else, yinc, !yabs
pfzout #Force Z axis output
if absinc$ = zero, *zabs, !zinc
else, *zinc, !zabs
pzout #Z output
if absinc$ = zero, zabs, !zinc
else, zinc, !zabs
pfcout #Force C axis output
if index = zero & rot_on_x,
if absinc$ = zero, *cabs, !cinc
else, *cinc, !cabs
pcout #C axis output
if absinc$ = zero, cabs, !cinc
else, cinc, !cabs
pindex #Index output
if index & rot_on_x,
if fmtrnd(prv_indx_out) <> fmtrnd(indx_out),
if lock_codes = 1 & rotretflg = 0, pbld, n$, *sunlock, "(UNLOCK)", e$
pbld, n$, `sindx_mc, indx_out, e$
if lock_codes = 1 & cuttype = 0 & rotretflg = 0, pbld, n$, *slock, "(LOCK)", e$
!cabs, !cinc
if arcoutput$ = zero | full_arc_flg$ | arc_pitch$,
#Arc output for IJK
if plane$ = zero, *i$, *j$, k$ #XY plane code - G17
if plane$ = one, i$, *j$, *k$ #YZ plane code - G19
if plane$ = two, *i$, j$, *k$ #XZ plane code - G18
else,
#Arc output for R
if abs(sweep$)<=180 | arcoutput$=one, result = nwadrs(srad, arcrad$)
*arcrad$
#Arc output for IJK
else,
#Arc output for R
*arcrad$
This section controls IJK so if you take out the * if will take care of that.
The pfxout, pfyout, and the pfzout force out X,Y,Z every time there is a Arc move. So if you change it to pxout, pyout, and pzout you will get them only, but make sure your machine can handle this change.
[ 08-07-2009, 10:13 PM: Message edited by: Crazy^Millman ]
Is this the area that your talking about? It has "`sgcode" what does ` mean?
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout #Output to NC of linear movement - rapid
pcan1, pbld, n$, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, strcantext, scoolant, e$
# pbld, n, "M01 (CHECK INSERT)", e
else, pcirout1
else, pcirout1
pxyzcout
ps_inc_calc
The " ` " means it is forced with a condition, it will come out only if something else on the line has to be outputed otherwise it won't come out.
As for the "*sgcode" you found in the pcircout1 block this one is only for the arc moves. You probably have one also into plinout, prapidout, and maybe a few other places.
How many places would you guess would have the *?
I'm nervous to change them because I've noticed it has some for the G28 G91 Z0 line and a few others that I need the 0 to be there. I guess I just need to be careful the ones I change and test my post after I change each one.
Sorry not getting back to this topic sooner but you answered your question:
This is how I have approached many changes to posts over the years. You are on the right path and asking very good questions soon you will be surprised how much you can do with posts.
