error while posting
MARK4566
I was using x3 and just switched to x4. All posts work fine except for one. We get an error while posting, when I look at th error report this is what it is:
24 Aug 2009 06:14:39 PM - <0> - Report created.
24 Aug 2009 06:14:39 PM - <2> - Initialize posting log file
24 Aug 2009 06:14:39 PM - <2> - Using MP run version 13.00 and post components version 10.00
24 Aug 2009 06:14:39 PM - <2> - Initiate opening the post processor file(s).
24 Aug 2009 06:14:39 PM - <2> - Post processor file name: C:MCAMX4MILLPOSTSMPMASTER.PST
24 Aug 2009 06:14:39 PM - <2> - The post processor file has been successfully opened.
24 Aug 2009 06:14:39 PM - <2> - Post version information (input):
24 Aug 2009 06:14:39 PM - <2> - UPDATEPOST Version 13. was used to modify this file.
24 Aug 2009 06:14:39 PM - <2> - The file was modified by this product on 19 Aug 09 16:54:23
24 Aug 2009 06:14:39 PM - <2> - The post was written to run with Mastercam Version 13.
24 Aug 2009 06:14:39 PM - <2> - The post product type is Mill.
24 Aug 2009 06:14:39 PM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
24 Aug 2009 06:14:39 PM - <2> - Search for defined post variables, strings, postblocks was successful.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'maxnccomment$' was re-initialized from 256. to 120.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'dec_seq_left$' was re-initialized from 3. to 4.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'sub_seq_typ$' was re-initialized from 0. to 1.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'tplanemode$' was re-initialized from 2. to 1.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'nobrk$' was re-initialized from 1. to 0.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'nobrkxz$' was re-initialized from 1. to 0.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'nobrkyz$' was re-initialized from 1. to 0.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'lnobrk$' was re-initialized from 1. to 0.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'lnobrkxz$' was re-initialized from 1. to 0.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'lnobrkyz$' was re-initialized from 1. to 0.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'arctype$' was re-initialized from 2. to 5.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'arctypexz$' was re-initialized from 2. to 5.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'arctypeyz$' was re-initialized from 2. to 5.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'larctype$' was re-initialized from 2. to 5.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'larctypexz$' was re-initialized from 2. to 5.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'larctypeyz$' was re-initialized from 2. to 5.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed4$' was re-initialized from 2. to 1.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed5$' was re-initialized from 3. to 1.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'lrotfeed4$' was re-initialized from 2. to 1.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'lrotfeed5$' was re-initialized from 0. to 1.
24 Aug 2009 06:16:02 PM - <2> - CONTROL DEFINITION - - Post variable 'sub_level$' was re-initialized from 0. to 0.
24 Aug 2009 06:16:02 PM - <2> - RUN TIME - PST(3596), NCI(96) - Result type is wrong for formula
24 Aug 2009 06:16:02 PM - <2> - Successful completion of posting process!
But at the end of it it says it posted successfully, so would it be ok to run??
I was told not to worry about the initialized lines, which it looks like all but one of yours. I would address this issue:
Thad
The problem probably is caused by one of the variables being used in this formula on line # 3596 not being declared or defined properly or being of the wrong type.
Without the post I can't even tell you what or where.
I suggest contacting your reseller or at least posting the bad line so we can take a stab or two at it.
You could also look at the post line concentrating around the formula ( = ) and look at the variable names. Varaiables that have a $ at the end are predefined and don't need to be declared or initialized - but there are two types - strings and numeric. You could be using say a string variable where a numeric variable is required.
But if this worked prior to updating or I should say that you never noticed the error before, because it was there in previous version trust me, then for each variable in the formula that doesn't have a $ - search the post for this variable. Somewhere in the post the variable must have been declared or initialized with a : (ie xour : 0) for numeric variables and something like this (string1 " " or string1 or string1 := "some text " if you can't find the variables declaration then that is the cause.
Hope this helps!
