X+ (support Lathe and CSS)
I've uploaded a new beta version of X+ on my website.
This version supports some basic lathe information in the setup sheet (incl. tool bitmaps) and also I've added support for CSS (cascaded style sheets). With CSS you have much more control over the HTML format. You can assign backgroundimages, frame-styles, font-styles, color-styles and much more. Some samples will be installed with the X+ installer.
Each saved config file (*.xss) can go with the same named CSS file (*.css), which will be linked to the HTML file. The CSS files are located in the X+ folder. The new CSS button will open the current CSS-file with notepad. Make your changes, save the CSS file and refresh the HTML-file in your browser. That way you can easy tweak your CSS-file.
Any comments or suggestions are welcome.
X+ beta
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Yes the new version support mill/turn i just install it a check if it's work and it'#1
i just need to copy the lang.dll of the previous version to get it in English
thanks Günther, as always your product is awesome, ive been waiting for an X+ version that support mill/turn for a couple of years now , and that day is today !!!
Dan, the above link is definatly the english lang.dll.
You need to extract and copy it to mcamx4chooksx+
Close mastercam before.
Ted, how did you install it? I guess something went wrong.
The installer should detect the mastercam main folder automatically.
Try the unistaller (uninstX+.exe) under the mastercam main folder. Then delete the X+ folder in the chook folder, if it is still there. Install X+ again.
And of course you need to close mastercam before.
Gunther, X+ is a great program, thanks for working on it!
All I have issues with are the "TEMP files. We use multiple setup sheets for each .mcx, and store these setup sheets in the same folder as the .mcx
If I make 2 setup sheets ( one for the top of a part, another for the bottom ) the 2nd setup sheet will overwrite the "TEMP" image that is stored in the destination folder for out File Setup in the .mcx file. What happens is this will overwite any images in our earlier setup sheets in that folder.
Any way to work around it?
Yes Gunther where it says "Logo.png". The only png ext I could find was a folder in the X+ folder in the chooks, it had pictures of the tools in it.
edit.. Just found it, its called a logo.
Thanks.
[ 10-07-2009, 07:01 AM: Message edited by: Dan@Vian Ent. ]
